Fri, Oct 4, 2:24 PM CDT
Vue F.A.Q (Last Updated: 2024 Sep 26 4:27 pm)
Subject: After having Vue closed for a couple hours now why is this still show in TM
dlk30341 ( ) posted Mon, 01 December 2008 at 5:59 PM · edited Fri, 04 October 2024 at 12:18 PM
As stated above.  I've had Vue closed for a couple hours now - why is this still showing in my task manager?  It's not using CPU cycles but it should'nt still be there taking memory :blink:
I believe I should be sending this off to tech support - hmmmmmm
dlk30341 ( ) posted Mon, 01 December 2008 at 6:06 PM
I just re-opened Vue & low & behold it shows it running 2 times!  WTH???
Shari123 ( ) posted Mon, 01 December 2008 at 6:55 PM
Just a thought, but could it possibly be allowing internet access to Vue? It could possibly be checking periodically for updates and linking to C3D.
dlk30341 ( ) posted Mon, 01 December 2008 at 7:00 PM · edited Mon, 01 December 2008 at 7:03 PM
Nope - All internet access denied, that's the 1st thing I unclick ;)
In fact I opened V6I - did some rendering & V6I showed in the mem column 188,732K while it was rendering!  Note V7i sitting idle(not even open) & see how much mem it's using just sitting there.......
I went ahead & sent in a tech ticket......this is just plain crazy :(
Shari123 ( ) posted Mon, 01 December 2008 at 7:08 PM
I discovered, strangely enough, that although I denied internet access to Vue 6I, it was in fact connecting to the internet anyway. I had to block it in my firewall to stop it from connecting. I don't have Vue 7 yet, so I can't relate my experiences there.
dlk30341 ( ) posted Mon, 01 December 2008 at 7:47 PM · edited Mon, 01 December 2008 at 7:48 PM
I have all that blocked :(. I'm at a loss......maybe tech will have an answer.  I have to wonder if maybe this maybe a reason why some people are having mem issues/rendering issues.  If peeps are shutting down & somehow Vue isn't totally closing this could have adverse consequences.
I know I will be checking the TM diligently from now on :rolleyes:
Shari123 ( ) posted Mon, 01 December 2008 at 7:54 PM
I was just curious, did you select the Vue 7 process and click end process in the task manager? I understand that it shouldn't be doing that, but I was curious as to whether it can be ended.
Paula Sanders ( ) posted Mon, 01 December 2008 at 9:02 PM
I just closed Vue 7 I and opened Task manager and checked Processes. It isn't there. What OS are you using? I'm on my laptop with Vista Ultimate 32-bit. I don't have any RenderCows in my sys tray. Just a thought.
wabe ( ) posted Tue, 02 December 2008 at 12:34 AM
I think what you face here is what I call a "hidden crash". Vue closes all windows first and then normally quits. When it crashes after all the windows are closed you have exactly that, a process still visible in the task manager. I btw have something similar with PowerPoint on Windows from time to time.
gillbrooks ( ) posted Tue, 02 December 2008 at 3:35 AM
I have thata happen often.   Not just Vue 7 but 6 also.  I did notice that it used to appear more often after a crash or if I'd had to kill the process.
If you get an explaination from e-on it'd be appreciated if you'd let us know 😄
Gill
dlk30341 ( ) posted Tue, 02 December 2008 at 8:24 AM
I'll be sure & reply back when I hear something back from tech.  Hidden crash - interesting.  Now that would be a coincidence! The only thing odd that happened was I imported a Poser wreath tried to resize it - it then completely vanished from the screen(even though still showing in the obj panel)  I shut Vue down, then reopened to have import success.  I'm guessing this hidden crash happened when the wreath disappeared.   How bizarre :blink:
dlk30341 ( ) posted Tue, 02 December 2008 at 8:55 AM
Tech has turned it over to development. So no explanation as of yet.
dlk30341 ( ) posted Tue, 02 December 2008 at 9:51 AM
Update - I just crashed Vue - filled out the auto ticket & Vue is still showing in the task manager.
