Vue F.A.Q (Last Updated: 2024 Sep 26 4:27 pm)
Nope - All internet access denied, that's the 1st thing I unclick ;)
In fact I opened V6I - did some rendering & V6I showed in the mem column 188,732K while it was rendering! Note V7i sitting idle(not even open) & see how much mem it's using just sitting there.......
I went ahead & sent in a tech ticket......this is just plain crazy :(
I have all that blocked :(. I'm at a loss......maybe tech will have an answer. I have to wonder if maybe this maybe a reason why some people are having mem issues/rendering issues. If peeps are shutting down & somehow Vue isn't totally closing this could have adverse consequences.
I know I will be checking the TM diligently from now on :rolleyes:
I think what you face here is what I call a "hidden crash". Vue closes all windows first and then normally quits. When it crashes after all the windows are closed you have exactly that, a process still visible in the task manager. I btw have something similar with PowerPoint on Windows from time to time.
I'll be sure & reply back when I hear something back from tech. Hidden crash - interesting. Now that would be a coincidence! The only thing odd that happened was I imported a Poser wreath tried to resize it - it then completely vanished from the screen(even though still showing in the obj panel) I shut Vue down, then reopened to have import success. I'm guessing this hidden crash happened when the wreath disappeared. How bizarre :blink:
I believe I should be sending this off to tech support - hmmmmmm
