I haven't used V4 as much as I should so this may not help: After conforming the stockings, have you applied a magnet pose to it? That is one of V4's features. If memory serves, the magnets should be in the Pose library. If that is a single figure in the scene, use the first pose.
Try seeing if there are any morphs you can use to fix the problem. Depending on the maker, they'll either be in the body group or in the individual area. A little tweaking can go a long way. Some merchants also put in morphs to fix things like bending problems.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
I didn't knownwhy..... althrough, thanks for anwser my question again....
Still wait for this problem....
I have that set too. That stockings match perfectly.
If the shown happens first make sure you used the magnetise pose for the stockings (from V4 pose library).
Sometimes it may be neccessary to delete the stocking and reload, conform and magnetise it again. Than all should be solved. You can do so while V4 is posed, no need going back to zero position.
I'm not sure but might remember that there was also such a notice in the accompanying readme.
Jo
THANKS!
Model: V4 Honyu's Corset2 Stocking.
