It's strange that the factory state reset didn't work. Are you sure it was the factory state setting on the Interface tab that you ticked, and not just the one on the Document tab?
Another possibility....
Poser uses XML files to store the position of each part of the UI within each Room. You just need to find the right entry in the right XML file and edit the vertical (Y) position to somewhere where you can then pick it up and drag it to where you really want it.
I'm at work right now and I don't have Poser here, but if you would rather do this than re-install Poser, I can look up which file and entry you need to edit, when I get home. Just leave a note here. Or maybe some other kind soul will tell you in the meantime.
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
The sizing isn't the issue, motox. The Poser UI is confused when you move the dragging area of a tool onto the "room" tabs. It will no longer let you grab the tool.
Factory reset should work - I think you should try again as you may not have clicked what you thought you clicked.
Also, if you happened to save any presets (that little 3x3 group of buttons) try clicking them. They might get you back to how you had things before.
Is there a Keyboard method or some other way to Move the Editing Tools than trying to click and drag them to place?
