Sun, Jan 5, 7:56 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 05 6:50 pm)
Subject: How can I...
Moonfire ( ) posted Fri, 19 December 2008 at 11:49 AM · edited Fri, 03 January 2025 at 6:41 PM
.....save 6 figures as a prop?
I'm working on a picture using the emitters and holo-lumi from the AS Bioflow outfit. I have them positioned in a line of three on her (Alice) upper right arm. They are all parented to her right shoulder and all the holo-lumis are parented to their respective emitters. The thing is..it took me ages to get them all set up and well quite frankly I'm lazy and was wondering if there's a way to save them so I can load it all at once.
Anyone got any suggestions?
ockham ( ) posted Fri, 19 December 2008 at 11:53 AM
Easiest probably is to save it as a scene. (PZ3 file.)  You can then merge
the whole thing with other scenes, using the File: Import menu choice.
Be sure to "clean out" the scene before saving: eliminate everything you
don't want to be bringing in again.  Especially, delete all the lights before saving.
My python page
My ShareCG freebies
Moonfire ( ) posted Fri, 19 December 2008 at 11:56 AM
So do I have to get rid of V4 and everything as well?
markschum ( ) posted Fri, 19 December 2008 at 12:14 PM
You should be able to save the fogure with all clothes and props to the figure library. Then when you add it to the scene everything should load together .
Save the scene first in full, so if it doesnt work you can try again.
lesbentley ( ) posted Mon, 22 December 2008 at 10:51 AM
Markschum is right. You can save everything to one cr2 (character file) in figure pallet (library). Props (pp2) parented to a figure will automatically save with the figure when you save it to the Figure Pallet. When a figure has other figures (cr2) parented to it you will get an option to save all the figures as a "Whole Group".
With your main figure selected, from the Library pallet on the right hand side of the Poser Document Window, choose the Figures pallet, if desired select a sub pallet, click on the + sign at the bottom of the pallet, and if prompted chose "Whole Group".
Parented lights will also be saved with the figure, but note that only one instance of a light name can exist in the scene, eg you can only have one "Light 4" in a scene. If you load a cr2 that contains a light with the same name as one already in the scene then the original one will be replaced by the one you load.
107Cornfields ( ) posted Tue, 23 December 2008 at 8:42 AM
Quote - Easiest probably is to save it as a scene. (PZ3 file.)  You can then merge
Is it possible to load a .pz3 file and literally mege it with another?
When I load a .pz3 file it is loaded in as a whole new scene - I dont get an option to merge the current scene.
Am I missing something?
Dizzi ( ) posted Tue, 23 December 2008 at 9:02 AM
Yes. File -> Import -> Poser Document/Prop
107Cornfields ( ) posted Wed, 24 December 2008 at 4:06 AM
Lovely - thank you
That should speed up development a lot
