Mon, Nov 25, 4:31 PM CST
Vue F.A.Q (Last Updated: 2024 Nov 21 4:12 am)
Subject: Odd V7I install issue
Gareee ( ) posted Fri, 19 December 2008 at 1:49 PM · edited Mon, 25 November 2024 at 4:24 PM
Ok, this has me non plussed.
V7I installed fine on my old system.
I'm trying now toi install it on my new system, and the first thing it wants to install are it's dependancies... BUT it's trying to install them back onto it's own dvd instead of c:wherever
Anyone heard of this, and have a solution?
Gareee ( ) posted Fri, 19 December 2008 at 1:58 PM
Called eon, and they suggested copying the dvd into a folder on my c crive, and then trying installation again.. crossed fingers!
Gareee ( ) posted Fri, 19 December 2008 at 2:20 PM
No luck there... trie even putting a blank dvd in the drive to allow it to write there, and that didn't work either. Looks like I'll have to wait on a support ticket.
Peggy_Walters ( ) posted Fri, 19 December 2008 at 2:35 PM
Is your new machine Vista?
LVS - Where Learning is Fun!
Gareee ( ) posted Fri, 19 December 2008 at 3:04 PM
yep, vista 64
I'm wondering if I got hit with that new bug thats going around already. (I did install the new critical updatesw, but you never know what's going on like that now a days)
I'm going to try going back to a restore point from yesterday, and see if that resolves the issue.
Paula Sanders ( ) posted Fri, 19 December 2008 at 3:42 PM
I had no trouble installing it into Vista 64-bit. It went right in to C:/program files/...........
What is this new bug and what does it do?
bruno021 ( ) posted Fri, 19 December 2008 at 4:32 PM
Same here, installed normally, looked for the dependencies on  the C drive, Vista64.
Gareee ( ) posted Fri, 19 December 2008 at 4:34 PM
I don;t know if it's a  bug, or if something else is going wrong. the installer fails when it tried to install it's dependancies, the c++ files. It attempts to install them back to the dvd, rather then in the windows system folders where they belong (I think)
The exact same dvd installed fine on my older system.
I rolled back to yesterday, and am doing a virus scan, to see if maybe that's the culprit. after that completes successfully, I'll try the installer again.
We're also getting high winds here right now.. we almost lost power a half hour ago, and our gazebo blew off our deck, taking the christmas lights with it.
Just one hell of a fun day.
Peggy_Walters ( ) posted Fri, 19 December 2008 at 5:24 PM
Ouch on the wind!  Hope everything is not too busted up.
Make sure you have Administrator rights and turn off the UAC.
Gareee ( ) posted Fri, 19 December 2008 at 11:27 PM
uac is already turned of..;)
artistheat ( ) posted Sat, 20 December 2008 at 9:05 AM
With some Apps I found out you have to delete everything that has to do with that program even in the Reg. and then you can do a clean installation. This is just one idea.:)
Gareee ( ) posted Sat, 20 December 2008 at 10:47 AM
it was never installed in the first place. this is a brand new system. I rolled back to litrally nothing installed, and vue still has this issue.. everything else installs fine though it seems.
Peggy_Walters ( ) posted Sat, 20 December 2008 at 11:56 AM
Wish I had a clue how to help - I haven't got a system worth putting Vista on yet.  Do you have all the updates for Windows Vista installed?
artistheat ( ) posted Sat, 20 December 2008 at 12:55 PM
Could your system be missing some type of .dll that it needs and you have to reinstall Vista to correct the problem...Again just another idea.I'm still using windows XP....
Peggy_Walters ( ) posted Sat, 20 December 2008 at 1:13 PM
Yeah - that's a thought, but maybe try to get the Microsoft c++ stuff from the Microsoft site.  They should have it as a download/patch.
Gareee ( ) posted Sat, 20 December 2008 at 1:41 PM
The c++ stuff is already installed. boththe older 2005 version (which poser pro installed I think), and the newer 2008 library. apparntly vue installs it anyway, even if it's already installed.
Everything else appears to be installing fine, so I have to suspect that its something odd in eon's v7I installer.
I might try installing V6I first, and seeing if that will install, and then try V7 after that.
I still have a lot of files to move, so I've put the V7I instll on the backburner, hoping eon comes up with a fix. Not sure what they'll do though, since my install disc did install fine on my old system, so it obviously isn't defective.
Maybe they'll give me a link for a download version, and I can try installing that, since I already have my serial number card.
