Sun, Oct 6, 2:25 PM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 06 11:30 am)
Subject: trouble importing obj into poser
Dave71 ( ) posted Fri, 19 December 2008 at 9:29 PM · edited Sun, 06 October 2024 at 12:28 PM
hi ya'll, i am back into this after a bit of a break due to illness, i am modelling in Silo and when i export the obj, i cannot import it into poser.
poser hangs when importing, i have the latest patches for poser and silo so i am not sure what the problem is, poser just hangs when importing.
thanks in advance
dave
ockham ( ) posted Fri, 19 December 2008 at 9:33 PM
Try importing some other OBJ that's in the regular Geometries folder,
like the OBJ for one of the primitive props.
If that doesn't work either, then you've got a problem in Poser itself .... most
likely the file FFOBJ.ARP in runtime/plugins.
If other OBJ files are okay, then you might try putting the bad one through
UVmapper.  Just load it and save it under a new name, without modifying
anything.  UVmapper often manages to straighten out an OBJ that's written
in some strange way.
My python page
My ShareCG freebies
Dave71 ( ) posted Sat, 20 December 2008 at 12:56 AM
i cant import any obj's..
it loads cr2's fine but obj's hang poser
PhilC ( ) posted Sat, 20 December 2008 at 4:29 AM
It may be that your Poser installation is corrupted. Try reinstalling the latest service release then if that does not work I think you will need to reinstall Poser.
Dave71 ( ) posted Sat, 20 December 2008 at 6:05 AM
thanx i will try that.
any user prefs i should get rid of when uninstalling?
pakled ( ) posted Sat, 20 December 2008 at 3:37 PM
depends on what you want to do, I suppose. I usually don't worry about prefs, unless they say it's causing a problem...
