Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 9:54 am)
Attached Link: "Fantastic Faces" tutorial compliments of Dr Geep Studios
*(click image to view full size) (click link above image to view complete tutorial) * Hi smalll,Maybe something in this tutorial may help.
Holiday Cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Can you give me more details about ...
What you have ...
And ... what are you not able to do ... ?
I downloaded your model and it appears that the neck IS attached to the head in the .obj file.
cheers,
dr geep ... :o]
edited 10/5/2019
Ok, I went and looked at your figure.
You need to turn ON "Bend" for the Head.
Also, you need to adjust the Head bone and then use the Joint Editor to adjust all of the neck/head joint parameters.
I will post a couple of more tuts here that may help you get it fixed.
Holiday Cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Thank you about your interest to my problem.
I need your help.
I maded a model - there is only head and neck.
And I bended head, then there occur gap. - You can see red circle.
I tested it in poser 5 and poser 7.
(I made model in 3D max.)
I do not want the gap.
I want to smooth bend.
What's wrong with me?
Can you help me?
Attached Link: http://drgeep.com/p5/sr/sr.htm
cheers,
dr geep ... :o]
edited 10/5/2019
Attached Link: http://drgeep.com/p5/db/db071.htm
cheers,
dr geep ... :o]
edited 10/5/2019
Attached Link: http://drgeep.com/p4/je/je.htm
cheers,
dr geep ... :o]
edited 10/5/2019
Attached Link: http://drgeep.com/p4/jp/jp.htm
cheers,
dr geep ... :o]
edited 10/5/2019
Attached Link: http://drgeep.com/p4/robox/robox.htm
cheers,
dr geep ... :o]
edited 10/5/2019
Attached Link: http://drgeep.com/p4/rrshop/rrshop.htm
cheers,
dr geep ... :o]
edited 10/5/2019
I need your help.
I tryed making a model.
I maded something.
It is so simple.
You can download it.
http://www.bokgi.net/test/Runtime.zip
It has only head and neck.
But, the head and neck does not attached.
You can see gap.
How can I fix it?
It is just a sample.
I want to know the way.
The way is important to me.
Please help me.
