Thu, Jan 9, 12:03 PM CST
Subject: Question about making a model.
smalll ( ) posted Mon, 22 December 2008 at 7:14 PM · edited Thu, 09 January 2025 at 12:00 PM
I need your help.
I tryed making a model.
I maded something.
It is so simple.
You can download it.
http://www.bokgi.net/test/Runtime.zip
It has only head and neck.
But, the head and neck does not attached.
You can see gap.
How can I fix it?
It is just a sample.
I want to know the way.
The way is important to me.
Please help me.
geep ( ) posted Mon, 22 December 2008 at 7:39 PM
Attached Link: "Fantastic Faces" tutorial compliments of Dr Geep Studios
*(click image to view full size) (click link above image to view complete tutorial) * Hi smalll,
Maybe something in this tutorial may help. 😄
Holiday Cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
smalll ( ) posted Mon, 22 December 2008 at 8:25 PM
Hi, geep.
Nice to see you.
Thank you about your help.
But, my problem remains still.
geep ( ) posted Mon, 22 December 2008 at 8:29 PM
Can you give me more details about ...
What you have ...
And ... what are you not able to do ... ?
I downloaded your model and it appears that the neck IS attached to the head in the .obj file.
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Mon, 22 December 2008 at 8:52 PM
Ok, I went and looked at your figure.
You need to turn ON "Bend" for the Head.
Also, you need to adjust the Head bone and then use the Joint Editor to adjust all of the neck/head joint parameters.
I will post a couple of more tuts here that may help you get it fixed.
Holiday Cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
smalll ( ) posted Mon, 22 December 2008 at 8:53 PM
Thank you about your interest to my problem.
I need your help.
I maded a model - there is only head and neck.
And I bended head, then there occur gap. - You can see red circle.
I tested it in poser 5 and poser 7.
(I made model in 3D max.)
I do not want the gap.
I want to smooth bend.
What's wrong with me?
Can you help me?
geep ( ) posted Mon, 22 December 2008 at 8:55 PM
cheers,
dr geep ... :o]
edited 10/5/2019
smalll ( ) posted Mon, 22 December 2008 at 8:56 PM
You right.
"bend' is the answer.
Sorry.
I didn't know that.
I am deeply grateful to you.
Thank you!!!
geep ( ) posted Mon, 22 December 2008 at 8:57 PM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Mon, 22 December 2008 at 8:59 PM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Mon, 22 December 2008 at 9:00 PM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Mon, 22 December 2008 at 9:02 PM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Mon, 22 December 2008 at 9:06 PM
cheers,
dr geep ... :o]
edited 10/5/2019
smalll ( ) posted Mon, 22 December 2008 at 9:27 PM
Wow!
It is a big christ mas present.
I can´t find the words to thank you.
Miss Nancy ( ) posted Mon, 22 December 2008 at 9:42 PM
smallll, poser cylinder prop may not have enuff axial polygons to support axial bending.
use subdivided cylinder prop.  turn on bending for cylinder prop.
smalll ( ) posted Mon, 22 December 2008 at 9:54 PM
Thank you Miss Nancy.
You are so kind.
I would take your lesson to my heart.
