Mon, Dec 23, 7:08 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 23 1:20 pm)
Subject: Poser Pro and High detailed models
Chippsyann ( ) posted Thu, 25 December 2008 at 5:41 AM · edited Mon, 23 December 2024 at 6:32 PM
Can Poser Pro handle an object that has a Polygon count of 200000?
DarkEdge ( ) posted Thu, 25 December 2008 at 6:25 AM
Well Simon is 80,000 so try loading 3 figures and see how well your system holds up. Poser is not the best at high poly handeling but your own system will play a part too.
Hope this helps.
replicand ( ) posted Thu, 25 December 2008 at 9:00 AM
 200,000 polys?! That seems excessive for any one model.
nruddock ( ) posted Thu, 25 December 2008 at 11:49 AM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=2858697&ebot_calc_page#message_2858697
> Quote -  200,000 polys?! That seems excessive for any one model.
The roadster that came with P7SE is huge, but loadable.
Chippsyann ( ) posted Thu, 25 December 2008 at 12:05 PM
Thanks for the help. That object is a car; looks really great, but a bit pricey.
(But I still might get it)
lmckenzie ( ) posted Fri, 26 December 2008 at 1:57 AM
Even Poser 4 will handle almost 400,000 polygons. It actually loaded the 488,00+ polygon version before I reduced it but I didn't scale and it was too big for the viewport. Of course it's just an .obj, not a figure and only simple textures but no problem even on an old 768MB/AthlonXP 2400+.
Chippsyann ( ) posted Fri, 26 December 2008 at 9:51 AM
Thanks, "Imckenzie"; if you see any of my images with a fancy sports car you'll know that you had a part in it...(all of you, thanks)
lmckenzie ( ) posted Sat, 27 December 2008 at 6:22 AM · edited Sat, 27 December 2008 at 6:26 AM
Go for it. I don't know about FireFly but I loaded the original yatch (which is actually 513,433 polys), 1 V4 & 1 V3 (scaled down to 6%), clothes, hair and textures - roughly 730,000 polygons - no problems. Then just to see what would happen I loaded two yatchs in a new scene. It took a few minutes to render but 1,026,000 polygons and change didn't faze the old lady. I suspect adding a full crew of bikini clad Vickies to both would break something badly though :-)
