Wed, Jan 29, 11:37 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 10:50 pm)
Subject: CHANGING RUNTIME BETWEEN POSER 7 AND POSER PRO
cg3dstudio ( ) posted Fri, 26 December 2008 at 8:38 AM · edited Wed, 29 January 2025 at 11:26 PM
HI,
I HAVE A HUGE RUNTIME LIBRARY IN MY POSER 7... CAN I COPY THIS RUNTIME FOLDER FROM MY POSER 7 TO MY POSER PRO ??
THE POSER PRO WILL READ THE COPIED RUNTIME FOLDER ??
markschum ( ) posted Fri, 26 December 2008 at 8:53 AM
You should be able to add it as an external runtime to Pro.
If you want to make a copy of it , copy it to a temporary folder, the copy the Poser pro runtime to the same folder, allowing it to replace any duplicate files , then copy the new combined runtime back to poser pro.  Do NOT simply copy the poser 7 runtime to Poserpro, that will break things .
hborre ( ) posted Fri, 26 December 2008 at 11:01 AM
You need to be aware that single huge runtimes will consideralbly slow down your app and system.  Really explore the feasibility of smaller external runtimes and stripping them down to the bare essentials.  There is no need to have everything installed if they are not going to be used immediately, and limit your content usage to immediate projects.  That way you can create your renders, then delete or transfer to other media the content you do not need anymore.
Gareee ( ) posted Fri, 26 December 2008 at 11:29 AM
IS YOUR CAPS LOCK STUCK? IF IT ISN'T YOU REALLY SHOULDN'T POST IN CAPS AS IT LOOKS LIKE SHOUTING TO EVERYONE ELSE, AND IS DIFFICULT TO READ.
See? This looks much calmer, and is much easier to read.
