Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 20 6:55 am)
I looked at the mat poses that MPE makes... and there is a texture there.....
KdColor 0.8 0.8 0.8 1
KaColor 0 0 0 1
KsColor 0.6 0.6 0.6 1
TextureColor 1 1 1 1
NsExponent 10
tMin 0
tMax 0
tExpo 0.6
bumpStrength 1
ksIgnoreTexture 0
reflectThruLights 1
reflectThruKd 0
textureMap ":Runtime:Textures:! Digital Dreams:Chair:chair.jpg"
but its not applying. I'm not sure why ALL of my props are like this.... not just mine!
"Mat Pose" files are a hack and not officially supported. They do not work for props that are not parented, just as wdupre said. They are officially "poses" not materials, and poses only apply to figures.
Previous to poser 6 if you had props that you don't expect users to parent to a figure you simply provided a pp2 prop file for each material option. after all prop files are not very large unless they have a lot of morphs. with poser 6 Efronteers finally added a multiple material file that will work on all content, its the material collection, and you can save and load them in the material room. You can also convert a mat pose to a material collection fairly easily with a text editor, and I believe that EF included a python script which converted mat poses to material collections.
I've never had problems with textures, but then I ALWAYS apply my textures by hand, since I node them and alter them anyway.
DPH
If there is a figure in the scene, the sugestion made by markschum should work, even if the prop is not parented to the figure. Just edit the line in the pz2 that says "prop SomeName_#" to read "actor $CURRENT". When there is no figure in the scene you won't be able to apply any pz2 to anything, but if you need to get round this restriction you can change the file extension of the pz2 to cm2 and place the file in a camera folder, cm2 file will work even when there is no figure in the scene.
The alternative, as wdupre said, is to create a material collection. But as you are not getting the + sign, that option seems ruled out for the moment. I don't know why you are not getting the + sign, you should be able to see it. Perhaps you have a camera selected as the active item instead of the prop, that would cause the + to be missing, or perhaps the bottom of the pallet has been dragged below the bottom of the screen, or is obscured by the Windows Task Bar?
To save a material OR a material collection you must be in the material room. Perhaps you're not?
Quote - "Mat Pose" files are a hack and not officially supported. They do not work for props that are not parented, just as wdupre said. They are officially "poses" not materials, and poses only apply to figures.
And, if you have two of the same prop, the Mat Pose usual ends up being applied to the first one, regardless of which catgirl collar you have selected.
Quote - And, if you have two of the same prop, the Mat Pose usual ends up being applied to the first one, regardless of which catgirl collar you have selected.
That's probably because one of the props will be named something like "Collar_1", and as no two props in the scene can have the same name, the other collar prop will be named "Collar_2". If the mat file uses the name "Collar_1", then obviously it won't work on "Collar_2". A way round this is to use "actor $CURRENT" in the MAT file in place of "prop Collar_1".
I cannot get any mat files to apply to any props, mats apply fine to figures...
I cant even get mats to apply to props I didn't make... However, props with textures already on them, load fine.
EX: Blossoms day umbrella is under props, I load it into scene, and go to pose to apply mats.... nothing happens and i get the 'error' ding from the computer....
I have restarted computer, reinstalled poser..... nothing works.
I'm using poser pro, have had it for a while but this is the first time this has ever happened.
