Tue, Dec 31, 9:18 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Dec 29 10:47 pm)
Carrara Free Stuff here.
Subject: Physics
mhscspo ( ) posted Thu, 01 January 2009 at 3:08 PM · edited Sun, 29 December 2024 at 3:42 AM
How do I get the HUMVEE to over the object instead of through it, or inter act with the terrain as well. I am using  Carrara Pro 7
sparrownightmare ( ) posted Thu, 01 January 2009 at 3:20 PM
Hmmm.  I don't do much animation but I would think putting in some key frames as the wheel just touches the log, then olace your rotational hotpoint on the back axle so you can rotate the vehicle while keeping the rear wheel on the ground, then another hot point when it is rotated and lace it so the front wheels roll up to the top of the log.  Then reverse the procedure for the downward roll and do the entire sequence again for the back wheel.  If Anyone thinks this is wrong let me know.  I haven't tried anything but simple aircraft flybys up until now.
bwtr ( ) posted Thu, 01 January 2009 at 4:52 PM
http://www.sparrowhawke3d.com/
These free plugins from Jeremy for C7 Version should be available in a few weeks.
Worthwhile adding to your arsenal.
Brian
bwtr
MarkBremmer ( ) posted Fri, 02 January 2009 at 11:41 AM
 This is actually a fairly complex request. Getting the Humvee to go over the object like a toy car is pretty easy to do. However, if you want suspension compression/extension and realistic bouncing of the vehicle coupled with acceleration and deceleration, you'll need to hand animate that. Plug-ins like DCG's Cognito can help. I don't know that the Sparrowhawk plugs are a good fit for this assignment since wheels won't be in contact with smooth ground.
Animating is not fast business. :-P
sparrownightmare ( ) posted Fri, 02 January 2009 at 11:45 AM
Lol Be patient.  Every time I try anything more than a simple flyby, my machines freezes.  Eegads.  It makes you wonder what the professional animation companies use for hardware nowadays.  Anyone have a used Cray?
Dennis445 ( ) posted Fri, 02 January 2009 at 4:06 PM
You have a place large enough for a Cray? :)
DocMatter ( ) posted Fri, 02 January 2009 at 11:13 PM
Sparrow-- I don't have a Cray, but my Uniblab's been getting a little fresh with Rosie the maid lately, so I'm looking to upgrade pretty darn soon!  ;)
bwtr ( ) posted Sat, 03 January 2009 at 12:01 AM
http://www.fishsa.com/lobster.php
THIS is what a REAL Cray means in South Aussie!
Brian
bwtr
ShawnDriscoll ( ) posted Sat, 03 January 2009 at 9:03 AM · edited Sat, 03 January 2009 at 9:04 AM
Rig the car to give it a suspension first.  Use physics only at the end of your animated stunt.  Give it a slight direction force.  Too much will send it tumbling.
mhscspo ( ) posted Sat, 03 January 2009 at 5:20 PM
mhscspo ( ) posted Sat, 03 January 2009 at 5:21 PM
Thanks for the all the imput
