You are importing into Vue, which has atmosphere, Sun etc, which poser doesn't.
You need to change your scene's atmosphere, and lights.
Vue doesn't import Poser's lights.
"I'd rather be a
Fool who believes in Dragons, Than a King who believes in
Nothing!" www.silverblades-suitcase.com
Free tutorials, Vue & Bryce materials, Bryce Skies, models,
D&D items, stories.
Tutorials on Poser imports
to Vue/Bryce, Postwork, Vue rendering/lighting, etc etc!
Could you post screenshots so we can try and help? :)
if the area is totally enclosed, you'd need to add torches with lights in or near them (if it's a historic or fantasy arena) or other lights if a sports arena.
If it's open to the sky you just go into the amtosphere editor, load different atmospheres ot find one you liek, or, make your own by adjusting the sun's position, add or remove clouds etc.
Setting up lighting is key to any render, and a very complex thing, in regards to artistic ability/knowledge and time taken to perfect it.
Some basic tips:
Usually sunlight should have 1.00 softness. This can can be increased if the sun is meant ot be soft through clouds, or a soft sunset.
Adjust the shadows of each light so they are around 85%, real shadows are rarely absolute.
see tutorials on imports and lighting in my signature by way!
"I'd rather be a
D&D items, stories.
I'll agree with the above post. Lighting is not only key but one of the hardest things to do correctly. I'll sometimes spend as long or longer balancing lights as I do setting up the scene. Setting up a set of lights in Vue that's similar to the Poser 3 light set isn't hard though if that's what you want.
In general you should find that Vue lighting is easier to do and that the combination of Vue lighting and the Vue render engine produces much more realistic results.
Ok,assuming it's an indoor arena
I'd suggest you make a quadratic spot light
put this above the arena floor, up near the ceiling.
you want it to be a very wide, soft spot light, throwing light as if from light in ceiling or whatever.
try something like this:
Colour: a light tan (torch light isn't white light, assuming you want it to look torch lit, sunlight ha sit's own colour by the way, it isn't pure white, iirc)
Softness 4.00 (if want more realism, but it does increase render times)
Spread: 65
Falloff 100 (so no hard edges to where the spot is)
Power: depends on scene
Edit the light, shadows to be 85% shadow density
if you don't mind longer ender times, adding a ligh gel can improve realism, if you want it to look like torch light.
Here i've made a simple arena, lit as suggested. :)
"I'd rather be a
D&D items, stories.
increase the spread as need :)
"I'd rather be a
D&D items, stories.
import the poser scene then load a different atmosphere (or work on the default and set it up the way you want it)
My Freebies
Buy stuff on RedBubble
you don't have enough experience of Vue i think, you really should sit down, and work through some of the tutorials in the manual, read some tutorials on sites like mine and GeekAtPlay, and get a real feel for Vue.
You are jumping in at the deep end! ;)
By all means perserve with your scene, but if you learn more of the basics, it will help with it :)
Taken me years to learn what I have, and folk like me, Chipp, Vladimir etc, share that, making it a LOT easier for you.
note on spotlights:
the larger the spread angle, the wider it gets, so a single spot light can fill an entire arena..however, it's all coming from one finite point, so you do see shadows radiating from that point.
it does render quickly though.
If you wanted to make a good torchlight, you'd start with a quadratic point light, add very slight tan or yellow light, 5 degree softness at least
and then add a LIGHT GEL, light gels are like masks over a light,
torch light, or bonfires, are never solid, all-encompassing lights, they flicker, a gell can be used to replicate that effect
on the light panel, select LIGHT GEL, browse to materials, Light Gels, pick one, try "Clouded Gel"
you cna also add a lens flare, edit the flare, so flare colour is the SAME as the light colour , make flare small, suitable for torch, candle or whatever, so you have a visible source of light.
such effects make for very slow renders, not so good for animaitons, but great for fine art renders :)
here is a pic of a light with lens flare on, and a light gel ON
"I'd rather be a
D&D items, stories.
subtle difference, but noticable one when doing fine quality work :)
"I'd rather be a
D&D items, stories.
Hello
I have complete scenes, some animated, that I want to render in vue. What I would like to do is to simply import into view and render.
Well vue opens to the default desert scene with the blue sky and sun and my scene is in the middle of that which I do not want.
How does one import just the poser scene and not get the blue sky and sun etc?
Thank you.
