Carrara F.A.Q (Last Updated: 2024 Nov 05 6:06 am)
If not using procedural you need to turn on the texture view like you do in the Assembler Room. Here its working fine.
Follow me at euQfiz Digital
Not a bug... look that your texture will be showed inside the grid, that is the UV area, so you need to reduce your UVMap to fit inside the grid.
Not all textures show up in the UV view. Bricks/tiles don't. But most Enchance:C textures do.
Sometimes you have to guess how big to make your UV's so that the shaders look good on your objects. Or re-scale your shaders to make them look good with your UV's.
Sorry blade but here works very fine...you are doing something wrong but at same time we cant see what is, if you want you can send me a PM to send me the file so I can check what is wrong.
Hi, all
Because in the UV View don't see the textures applicate on the shaders ?
Select the face and aplicate UV planar but the texture in UV View don't see.
In the carrara 6 the texture to see .
Help
Carrara 7
Thanks
