Morph targets must have the same number of vertices as the base object.
If you used the subdivide tools of ZBrush, the number of vertices will change, and it won't work as a morph target.
Try the following steps:
If the Wavefront .OBJ files has the wrong number of vertices, Poser will warn you.
Now P4 Nude Woman should have a new head morph target. Try it at value 1.0 - it should look like the head in ZBrush.
Also try it at value 0.5 - if the vertex order has been messed up, the head will look very strange. In that case, you must delete the morph target and load it again, this time with "Reorder vertices" checked. Sometimes it helps, but it's no guarantee.
There is no need for MorphManager.
I think I found the problem.
Your Poser is probably set to use external binary morph targets. So it creates .pmd files, and MorphManager cannot use those.
Here is how you can fix that:
Poser will still load figures with external binary morph targets correctly, but it will no longer save morph targets as external files. Instead, morph targets are saved in the .CR2 file.
Now load your morphed P4 Nude Woman from the Poser Library.
And immediately save the figure back to the figure library.
Now the morph data will be contained within the .CR2 file, and now MorphManager can work with the morph.
And thanks for the compliments; glad you like my work!
Glad I could help. Good luck with your models!
Hi.
I need your advice.
I made morph target about head by zbrush.
It's base is P4 nude woman.
And I used Morph Manager.
I copyed my head morph to another P4 Nude woman.
Copy is successful.
But morph does not applied in poser.
My final purpose is next.
I want to make model with same head.
And I will combine different body (Aiko, V3, V4, ...)
I want apply same morph head by uesing Morph Manager,
But, It does not applied.
I think you have morph manager. (http://www.morphography.uk.vu/dlutility.html)
And you can download my model (test-1) by below link.
http://www.bokgi.net/test/Runtime.zip
And I used Poser Pro.
Can you help me?
