Sat, Jan 11, 11:06 AM CST
Subject: Remove Materials
pappy411 ( ) posted Thu, 08 January 2009 at 6:46 PM · edited Sat, 11 January 2025 at 10:46 AM
is there a script to remove materials from a .cr2 so they don't show up in the material room?
nruddock ( ) posted Thu, 08 January 2009 at 7:32 PM
Quote - is there a script to remove materials from a .cr2 so they don't show up in the material room?
No, you have to edit them out with either a text editor or one of the specialised Poser file editors.
Also don't forget to remove any unused materials from the corresponding OBJ (and possibly MTL) files otherwise they'll reappear (with a random colour).
pappy411 ( ) posted Thu, 08 January 2009 at 7:50 PM
Thanks nruddock,
I used a bone structure from one of my models in the setup room on another model I made and the material zones were transferred to the new figure.
I deleted these material zones in the .cr2 and they do not show up in the material room.  But when i load the object that the material zones were removed from I get a window saying "}" cannot be found.
PhilC ( ) posted Thu, 08 January 2009 at 8:55 PM
The Poser Pocket Knife has the delete surplus materials tool that you require.
Miss Nancy ( ) posted Thu, 08 January 2009 at 10:30 PM
pap, dimension3d also has got some scripts which are usefull with materials room chores.
markschum ( ) posted Thu, 08 January 2009 at 10:41 PM
Do you mean remove the material zones , or just set the texture back to a basic white ?   I have a script somewhere to clear materials  or you can just do one manually and use the Apply to All option in the material room pulldown , top right.
pappy411 ( ) posted Thu, 08 January 2009 at 10:59 PM
Thanks to all for the info
Pappy
