I don't know exactly why , but you can try to pose them manually in the right position then save them as a new cr2 ; load this cr2 and see if they conform properly after that.
Alice's and
GND4's Tailor !
Check my free clothing
fits : www.alizea3d.com
Thanks for the reply. I saved a new cr2 with the boots in the zero position and then tried posing just the boots with the same result. Falloff zones are properly adjusted.
The boot dials (bend/twist/side) work perfectly and the boots conform perfectly. They just won't strike a pose from the Pose library without this weird displacement. This won't disrupt the product at all as the boots will most likely always be conforming to a figure and can always be dial spun too...just never had this happen before. I wonder if it's just a little buggy for the day.
I see what you mean . I've just saw this thread :
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2760084
maybe it's a question of bones hierarchy - try to rig them by keeping more bones - thighs and hip .
Alice's and
GND4's Tailor !
Thanks again for replying.
Yes, I am aware of editing bones...always keeping the hip and one bone more past the end bones. This is happening with all of the bones still intact.
Like I said I've always been able to pose my armor/clothing by themselves using this same method (devolper rig) and this is the first time it's been trouble.
Perhaps a broken Ik chain? or the foot has come unparented to the shin? It looks like the feet are translated but not the shin. Did you save the pose with the IK on? I have seen this often with translated feet or hands, where the shin or forearm does not pick up the translation, but still assumes the bend of the pose.
Have you tried loading the developer rig into the imported boots object in the Setup Room? I suspect this might eliminate the weird default pose. As to why it is happening, I have no idea, but when one road is closed we must take another, regardless of the cause.
When the boots are conformed to Simon they behave and pose as expected as you can see in the attached pic. But with the boots not conformed to anything and just Posed by them selves the result is the following pic, next thread...
