Thu, Jan 9, 5:53 AM CST
Subject: Sharp image on 1 sided square
brewgirlca ( ) posted Fri, 09 January 2009 at 3:58 PM · edited Mon, 23 December 2024 at 1:58 AM
I have been using Bagginsbill's advice on how to attach an image to a 1-sided square to create a background. But the image always renders slightly blurry compared to if the image is just imported as a background or pasted in with photoshop. I need to have the image on the square so that it will show up in a water reflection.
Anybody know how to make the image on the 1-sided square sharp in the materials room?
Digger1967 ( ) posted Fri, 09 January 2009 at 4:09 PM
If your using Poser 7 / Poser Pro:
http://www.renderosity.com/mod/blog/display.php?member=Digger1967
If your using poser 6, you can shutoff the texture filtering as part of the rendering options.
Hope that helps.
bagginsbill ( ) posted Fri, 09 January 2009 at 4:15 PM
Two more points.
  1. Decreasing Min Shading Rate below 1 can help.
  2. You probably want to set Diffuse_Value = 0 and Specular_Value=0 and plug the image into Alternate_Diffuse. Only plug it into Diffuse_Color if you want your lights to light it and shadows to fall on it. For example, if the image is of a stage curtain, then light it. If it's an outdoor sky/trees/ground then don't light it - use alt diffuse. That channel is a straight passthrough to the render. The Diffuse_Color channel goes through an internal Diffuse node first.
brewgirlca ( ) posted Sat, 10 January 2009 at 1:41 AM
Thanks Bagginsbill, that worked better
Digger1967 ( ) posted Sat, 10 January 2009 at 2:44 AM
See, this is why I've all but given up on giving people helpful tips in the message forums.  Somebody adds information to my original post, they get thanked, I don't.. lol..
Oh well, such be life I guess.
