Fri, Nov 15, 10:59 PM CST
Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Subject: Dark Horizon
mdbruffy ( ) posted Sat, 10 January 2009 at 5:51 PM · edited Fri, 15 November 2024 at 10:46 PM
Spent the last 2 days getting VUE 7 Espirit installed and my VUE 6 Espirit content transfered. Now, the problem is this- using just the default settings, I set my first picture to rend to disk- saving it in the "My Picturtes" file like I laways did with #6. But instead of a picture, all I got was a black square- no image at all.
 Does anyone have any idea what I might have forgotten to set or pick?
After 2 days of wrestling with this thing, I'd really appreciate any help.
mdbruffy
silverblade33 ( ) posted Sat, 10 January 2009 at 10:28 PM
Ok always post system info and what build of Vue you have :)
You have updated to latest version of update for Vue?
Rutra ( ) posted Sun, 11 January 2009 at 2:06 AM
Does the preview of this picture render well on screen?
Assuming it could be a memory problem with your render to disk, have you tried to render to disk a smaller rez version of that same image?
mdbruffy ( ) posted Sun, 11 January 2009 at 5:24 AM · edited Sun, 11 January 2009 at 5:25 AM
I have VUE 7 .20-04 .
   I use Windows XP with 4 GB of memory installed on a Dell inspiron 531. The image renders fine in Preview, but I still get a black square when I try to render it to disk. In the render options, I checked Final, internal renderer,render to disk, under those options, I gave it a title and set it to save to "My Pictures" folder, I then skipped over to picture size and resolution, where I set it for Academy standard Flat [37:20], 900 X486 and a DPI setting of 300.
   These are the same settings I used in VUE 6 Espirit and they worked fine.  I'm forgetting to set something- but I don't know what.
Rutra ( ) posted Sun, 11 January 2009 at 5:38 AM
Everything seems fine.
Anyway, with such low resolution (900x486, if I understand correctly) why are you rendering to disk? A render to screen should work fine and it has the advantage that you see the render as it progresses and so you can do an early detection of problems. Normally, the render to file is used for very large image sizes.
mdbruffy ( ) posted Sun, 11 January 2009 at 5:51 AM
For me that's large enough  and it still lets me reduce size if i need to for my graphic novel work.
 So if everything's fine, why am I not getting a picture? Would a larger size make a difference?
mdbruffy ( ) posted Sun, 11 January 2009 at 6:13 AM
Changed the settings so it would render to screen- and it did that fine. But I can't figure out why it won't render to disk.
Rutra ( ) posted Sun, 11 January 2009 at 6:17 AM
If the same file renders fine to screen and not to file, this could be a bug. I suggest that you submit this to e-on.
mdbruffy ( ) posted Sun, 11 January 2009 at 6:31 AM · edited Sun, 11 January 2009 at 6:32 AM
I did- yesterday. I'm still waiting for a reply. I've heard about some patches that were released for the other 7's - Infinate and Pro- but I haven't seen or heard about any for Espirit.
luchare ( ) posted Sun, 11 January 2009 at 4:40 PM
yes, i get that too on pro....i thought i was going nuts.
mdbruffy ( ) posted Sun, 11 January 2009 at 4:43 PM
I started a thread on eon's forums- "Dark Screen". I've also filed an e-mail - what they call a "ticket" with their tech support. But it'll be sometime tomarrow before they answer it.
