Forum Moderators: Staff
The MarketPlace Wishing Well F.A.Q (Last Updated: 2025 Jan 04 10:16 am)
Have an idea for a MarketPlace product? Would you like to let the MarketPlace Merchants know?
This is the place!
Make sure you check The Product Showcase Forum and The Product Showcase Art Gallery.
Something like this ? I am still working on this to add a control panel
s291.photobucket.com/albums/ll317/markschum/
[sorry I could not get an image tag to work]
The base and upper and lower shell are uv mapped but its intended for Poser 5 and up materials
There are material zones for base, upper shell, lower shell, glass and lamps, and the hinge is 3 materials
It may be a commercial product so I wont post it but will send a copy .
I like mechanicals and usually have stuff that would support a battleship :)
I actually forgot a part at the back between the two shells that supplies a cooling airflow.
And you remembered the handles to open and close it .
These are kind of fun projects to try out , a sort of speed modelling challange.
Very nice.
The picture I have also shows a hydralic strut at one end that takes the weight of the top shell. They are a pain to set in Poser so I was going to leave it out.
This is what I am using as a reference http://www.alphasun-usa.com/images/asusa-shadow.jpg
from this page http://www.alphasun-usa.com/hometanningbeds.html.
I figure some artistic license can be used .
Just out of curiosity what do you model in ?
The hydro-struts were in my reference also, for the same reasons have avoided that part. The cooling vents on your reference are much more pronounced. Ones I viewed had smaller vents on the interior surfaces of the bed.
"Just out of curiosity what do you model in ? "
To answer you question, Mostly I model in my spare time.
Huh, oh... I do almost all my work with Blender. On occasion I'll fall back on 3ds max. After I've the model built I'll export out as .obj then work up the textures, figures, morphs... in Poser. Most recently I got Carrara which is what I've used on the last set of renders here.
My poser Characters need to get tan!
Hydra
