Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 10:50 pm)
My SpawnCharacterP6 (here in freestuff) script might be useful here.
Create your morph using whatever method and tools you like, and load it onto the character.
Make sure NONE of the DAZ morphs have a setting other than zero, in fact, if the morph is for M3, it's best to UNload all DAZ morphs from him!
Now run the SpawnCharacterP6 script. It'll create an INJ/REM pose pair for you, you can even select which PBM_CC channel it should use!
It'll be a full body morph pose, you'll have to strip out everything that's not on neck, head and possibly eyes. I use CR2Builder by kim99 (free download) for this kind of work.
Quote - My SpawnCharacterP6 (here in freestuff) script might be useful here.
Make sure NONE of the DAZ morphs have a setting other than zero, in fact, if the morph is for M3, it's best to UNload all DAZ morphs from him!Now run the SpawnCharacterP6 script. It'll create an INJ/REM pose pair for you, you can even select which PBM_CC channel it should use!
Thanks for all the info svdl, I'll DL your script and CR2Builder and see if I can make sense of it as I'm still on a huge learning curve in this area. :)
Pandorian's Website.... aka......
I wanted to know if there were any programs out there similar to "OBJaction Mover"? Anything that would help me to extract the differences between the original base file of a figure (IE M3) and a new modified morph target file I would create for it (IE a facial morph) ?
Otherwise a link to some good tutorials dealing with this would be equally helpful.
Thanks in advance
-J
