Fri, Dec 27, 8:22 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 27 7:02 pm)
Subject: Help with thumbnail again I have an image example
datastorm ( ) posted Tue, 03 July 2001 at 10:10 AM ยท edited Fri, 27 December 2024 at 3:45 AM
The image in the black circle is what I keep geeting. The image in the red circle is what I'm trying to produce. What am I doing wrong. And I did use utility in the free area to create change the pic file to an rsr. Any suggestions
JKeller ( ) posted Tue, 03 July 2001 at 10:43 AM
You need to change your video settings to 32bit.
raven ( ) posted Tue, 03 July 2001 at 10:44 AM
Set your display to 32 bit colour, that should solve it for you.
PhilC ( ) posted Tue, 03 July 2001 at 10:45 AM
Using a screen resolution of 1024x768 32 bit Truecolour, a neutral gray background (RGB 140,133,127) and I think the default light set, my thumbnails are created in the fashion you require.
datastorm ( ) posted Tue, 03 July 2001 at 11:16 AM
It worked! The RGB background setting 140,133,127 that you gave me worked! That was the problem. I got the transparent background and the drop shadow too. Yahoo! Thanks Phil, Jim, JKeller, raven.
