Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 11 2:52 am)
Attached Link: http://forum.daz3d.com/viewtopic.php?t=77881&highlight=dzinstall&flatnum=1
See link for solution with the DAZ installer bug:
ok, it now proceeds to the 'Destination Directory' but I now get a warning that
"When used with Poser TM, "Michael 4 Base" must be installed to the same directory as the application executable; due to restrictions on support file locations"
Please select the dir that contains your Poser Executable"
I have Poser finstalled in 2nd partition (F) in F/program files/ Poser Pro
so I choose that as the path and it just keeps popping up the same message.
any ideas
Mike
Hi all,
I am running PoserPro on a xp 64.
I just D/L'ed Michael 4 base from DAZ with the view of installing him into PoserPro, Firstly is he compatable?
I select 'Poser (all files)' from as the target application and then I get an error about reading the dzinstall.ini, Does this mean i must have DS installed on this pc for this to install properly into PoserPro?
Are there any installation issues I should be aware of?
how does M4 compare with the G2 males ?
thanks for help,
mike
