Fri, Dec 13, 12:33 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 12 6:08 pm)
Subject: Installing DS M4 into Poserpro - newbie needs some experienced advice.
Aussie-Mike ( ) posted Fri, 16 January 2009 at 12:27 PM · edited Wed, 11 December 2024 at 10:58 PM
Hi all,
I am running PoserPro on a xp 64.
I just D/L'ed Michael 4 base from DAZ with the view of installing him into PoserPro, Firstly is he compatable?
I select 'Poser (all files)' from as the target application and then I get an error about reading the dzinstall.ini, Does this mean i must have DS installed on this pc for this to install properly into PoserPro?
Are there any installation issues I should be aware of?
how does M4 compare with the G2 males ?
thanks for help,
mike
wimvdb ( ) posted Fri, 16 January 2009 at 2:28 PM
Select DAZ Studio during install of M4 and then browse to your PoserPro runtime folder.
For some unknown reason the DAZ installer does not recognize PoserPro. It only recognizes Poser 7 and earlier.
The Poserpro runtime is likely in your User folder depending how you installed PoserPro
Aussie-Mike ( ) posted Fri, 16 January 2009 at 3:28 PM
cheers wimvdb,
any thoughts on how the G2 models compare to M4?
Mike
DarkEdge ( ) posted Fri, 16 January 2009 at 5:25 PM
You can also just create a text document in your PoserPro folder and rename it to Poser.exe...
then your installer will think all is fine. 😄
Dizzi ( ) posted Sat, 17 January 2009 at 4:25 AM
Attached Link: http://forum.daz3d.com/viewtopic.php?t=77881&highlight=dzinstall&flatnum=1
See link for solution with the DAZ installer bug:
Aussie-Mike ( ) posted Mon, 19 January 2009 at 9:33 AM
ok, it now proceeds to the 'Destination Directory' but I now get a warning that
"When used with Poser TM, "Michael 4 Base" must be installed to the same directory as the application executable; due to restrictions on support file locations"
Please select the dir that contains your Poser Executable"
I have Poser finstalled in 2nd partition (F) in F/program files/ Poser Pro
so I choose that as the path and it just keeps popping up the same message.
any ideas
Mike
Dizzi ( ) posted Mon, 19 January 2009 at 11:44 AM
You probably need to create a Poser.exe inside the runtime you want to install to. Only versions prior to Poser 7 (latest SR) should have problems with M4 outside the main runtime, so Poser Pro isn't affected.
