Forum Moderators: Wolfenshire, Deenamic Forum Coordinators: Anim8dtoon
Photoshop F.A.Q (Last Updated: 2024 Sep 19 10:49 pm)
I came in here myself for this answer. I am using a 9800GT with 1G onboard RAM and 4 G system memory...more than adequate but i get the same thing...No GPU support for me either.
The most beautiful experience we can have is the mysterious. It is the fundamental emotion that stands at the cradle of true art and true science...
I'm sure this must be a video card driver thing or something because it worked for me once I installed CS4, since then, updating my video card driver and it's no longer available.
I'm not too confident installing the 3rd party plugins for the GPU as it's not supported by Adobe (being the main reason), but because I know it works, it's ust for some reason CS4 now wants to be picky as to which video card driver is installed. and I'd rather not rollback my driver (though I may have to) to get GPU to work if I can still use CS4 without it, I really wanted to be able to use the rotate view tool though.
Dell XPS M1730
Intel Core 2 Duo T9500 2.6Ghz
500GB (2x 250GB) RAID 1 Sata HDD
4GB RAM
Nvidia GeForce 9800M GTX SLI
http://kb.adobe.com/selfservice/viewContent.do?externalId=kb404898
This will help as GPU is turned off by default and needs the card to be enabled
Danny O'Byrne http://www.digitalartzone.co.uk/
"All the technique in the world doesn't compensate for the inability to notice" Eliott Erwitt
For most people, with up to a 12-megapixel or doing Web design work, the difference you will see is pretty negligible. It has been suggested that the inflection point from 32-bit to 64-bit happens where you would have run out of memory and would have had to go to your virtual memory system, storing data on the hard drive rather than in memory. So this is where I would suggest you will now find a tenfold performance increase opening up a large file. And also when you magnify the image the pixels remain sharp and does so with remarkable smoothness.
I'm using CS4 Extended and for some reason the GPU Accelleration is now no longer available, The only thing I have done is to update my Video Card Drivers that I can think of, but I would Ideally want to keep the latest version of drivers installed because I use this machine for playing PC games too.
Has anyone else had this problem in CS4?
Dell XPS M1730
4GB RAM
