Carrara F.A.Q (Last Updated: 2024 Sep 29 9:32 am)
And you can use alpha channel for better composite in After Effects, so you dont need a green backdrop.
Follow me at euQfiz Digital
The problem with Carrara's alpha channel in render is that it doesn't handle blurs well, so if you're rendering with motion blur, you're better off using a chroma-key green background and doing the composite with Keylight in AfterEffects. Keylight handles blurs and semi-transparent areas really well, in my experience.
- Dex
I see, never did something with motion blur... by the way can you show your work with Carrara?
Reflections on being slow
I know I should have thought of this a long time ago (been using since ver.3) so please don’t make fun of me.
My animations in carrara 6 mostly involve showing some kind of process using my companies CAD models.
I usually set the BACKDROP to cromakey green to later comp in After Effects or Vegas.
I was never much satisfied with the way the reflections turn out.
Most of the models I work on are of machined metal components.
Just last week I realized I could have a reflection map in the BACKGROUND channel and still use the green screen in the BACKDROP, thus getting the nice metal reflections and still render out to a good key.
DUUUUUUUU
