Sat, Jan 25, 3:29 AM CST
Subject: Matrix scene WIP
L&A ( ) posted Wed, 04 July 2001 at 8:18 PM ยท edited Mon, 20 January 2025 at 8:26 AM
I'm realy proud to present one of my first scene I made In 3DS Max even if it's not over yiet. I know that it's not the good forum but 1) the caracter that will be added are made in Poser 2) I think there's a lot more people in this forum than in any other. Please give comments
Wadus ( ) posted Wed, 04 July 2001 at 8:29 PM
looks great to me is it gonna be the bullit time scene?
L&A ( ) posted Wed, 04 July 2001 at 8:36 PM
Exactly, but it will be tough I will have trouble to do air waves for bullets unless my partner has an idea. I said that it was in progress because the surrounding building are missing and other stuff. Thanks for your reply.
chanson ( ) posted Wed, 04 July 2001 at 10:54 PM
I've never tried air waves as you describe, but I wonder if a Bryce volumetric with an abnormal refraction might do it...
veamon ( ) posted Thu, 05 July 2001 at 12:33 AM
if you have adobe premiere, you could import your movie, then export as a filmstrip and load it into photoshop, then use the circle tool and either "twirl" or "ripple" filter it...only problems is youd have to do frame by frame...
visualkinetics ( ) posted Thu, 05 July 2001 at 1:18 AM
Actually, if you used veamon's method described using Photoshop, then use Kai's Power Tool 6.0 filter called KPT Turbulence, which will actually put a rippling effect on the picture and can export as avi files too.
veamon ( ) posted Thu, 05 July 2001 at 1:49 AM
you would still have to do it frame by frame though right? that can be a hassle, i did one with just adding a lightsaber blade and glow for a 3 second clip and it took forever to draw...
L&A ( ) posted Thu, 05 July 2001 at 8:46 PM
Don't forgot that the camera moves, there's a refraction. I think that it should be made in 3D. I tried something with Torus and animated size and taper with a Raytrace texture and it gave me a good result. The only problem is that I have to do many toruses and animate everyone individually. Chanson, you're trick is very good, but I'm learning Max and try to do it all in Max. Thanks for helping me. I think that your advice can be use for an fixed image.
