Regarding the skin, it's hardly surprising it has so much plastic shine. The Specular value is set to 1 with a fairly bright Specular colour. I would change the Specular colour to quite a dark grey. Or dark gray if you are in the US.
:O)
Izi
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
Quote - Regarding the skin, it's hardly surprising it has so much plastic shine. The Specular value is set to 1 with a fairly bright Specular colour. I would change the Specular colour to quite a dark grey. Or dark gray if you are in the US.
:O)
Izi
Many thanks to you and the good Dr Geep.
Hard to believe, this is a retail product from a reputable location.
"That government is
best which governs the least, because its people discipline
themselves."
Thomas Jefferson
Well, to be fair it does also depend on how you are lighting the scene. True, this is a very crude skin shader, using just the PoserSurface built-in diffuse and specular settings; but with appropriate lighting it might look somewhat better.
I would guess that your main (front) light has a strong specular content, adding to the built-in specularity and giving the really plastic look. It might be worth turning off the specular content of your main light (leaving the skin shader as supplied) and see what results you get then, if only as an experiment.
By the way, reducing the Highlight value actually sharpens any reflection you may be getting, making the surface appear smoother. Materials like glass and chrome have very smooth surfaces (low Highlight values) and so produce sharp reflections. Skin/paper etc. have many surface imperfections (higher Highlight values) and so produce more diffuse (spread out) reflections. The Highlight value is not how much reflection you get, but how spread out it is due to small imperfections on the surface.
Izi
what I should be."
Murakami)
Quote - ...Hard to believe, this is a retail product from a reputable location.
I bought V4 Elite. A really nice set of textures and shaders. However, the AO is turned up to 25+or so around her eyes and mouth by default even when choosing a non-AO version of the texture. You have to turn it down manually or she looks like she was on a two week crack binge.
Any excellent product but, with a setting that got overlooked. It's not surprising, IMO. But, the problem is that a good many people don't know how to fix such things. So, what some producers may overlook because even if there was a problem, it'd be trivial for them to fix, turns into a much larger concern for many end-users who don't know how to fix it.
No, it was supposed to be a sinister character.
None of the promo images even look like that Ken Plastic Doll Skin.
Let's just say that is touted to look similar to this Rendo Forum Pic, without the opaque eye covering.
"That government is
themselves."
Thomas Jefferson
Quote - Well, to be fair it does also depend on how you are lighting the scene. True, this is a very crude skin shader, using just the PoserSurface built-in diffuse and specular settings; but with appropriate lighting it might look somewhat better.
Izi
Once again, thank you very much for the information.
Apparently this item appears to work fine in Default D|S, which I suspect it was created in.
It appears that it wasn't really checked out in Poser.
"That government is
themselves."
Thomas Jefferson
Attached are the Torso Poser 7 Material Room settings.
This retail item renders like a Shiny Plastic Ken Doll.
What surfaces and values would be the best choices for making it look more like skin and far far less shine?
Many thanks
"That government is best which governs the least, because its people discipline themselves."
Thomas Jefferson
