Sat, Nov 9, 6:01 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 09 3:34 pm)
Subject: toon renders
RedPhantom ( ) posted Sun, 08 February 2009 at 5:52 PM · edited Sat, 09 November 2024 at 5:53 PM
Site Admin
Sorry for yet another thread about toon renders but I can't find what I'm looking for. Can anyone help me with doing a toon render or direct me to a thread for doing this? Please.
JenX ( ) posted Sun, 08 February 2009 at 6:03 PM
What effect are you trying to achieve?
RedPhantom ( ) posted Sun, 08 February 2009 at 6:56 PM
Site Admin
mostly looking like a comic strip. I tried using sketch render but there is too much shading.
Rance01 ( ) posted Sun, 08 February 2009 at 7:02 PM
What version of Poser?  In P6/7 there's a wacro to set up Toon shaders.  Seem's like Olivier (spelling?) was putting together a toon shader package some time ago.  He's over at RuntimeDNA.  I'm pretty sure it's a comercial package.
Off the top of my head I don't know of any tutorials.
Best Wishes,
Rªnce
JenX ( ) posted Sun, 08 February 2009 at 7:02 PM
Ok, that doesn't narrow it down :)  Do you have a link to a type of effect you're looking for?
Rance01 ( ) posted Sun, 08 February 2009 at 7:08 PM
RDNA is not an easy site to find anything on, and I hate FLASH animated ads but I found Olivier's Cartoon Shaders within a few clicks.  It's not inexpensive but I'm sure it's a quality product and there would be plenty of support for the thing.
Good luck with your search.
R-
RedPhantom ( ) posted Sun, 08 February 2009 at 8:28 PM
Site Admin
something kinda like this. It looks rather 2d-ish, but I can't draw people in 2d programs.
geep ( ) posted Sun, 08 February 2009 at 8:29 PM
Attached Link: http://drgeep.com/p6/cc/cc.htm
*(click image to view image full size) (click link above image to view the tutorial)*
You might find something of interest in this tutorial. 😄
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
ima70 ( ) posted Sun, 08 February 2009 at 8:36 PM
Here is a very simple toon tutorial, it may help you to start.
http://www.posetteforever.com/discussion3228.html?p=39406#p39406
RedPhantom ( ) posted Sun, 08 February 2009 at 9:21 PM
Site Admin
the posette forever link wasn't working. But thanks for the attempt.
thanks Dr. Geep. Your tutorial did help. Got want I needed :)
estherau ( ) posted Sun, 08 February 2009 at 10:33 PM
Attached Link: http://www.runtimedna.com/mod/bcs/index.php?ViewProduct=2139&TopID=174673
 this is what I use from rdna by oliver, with shader works for quick applicaton of effect Love esther
MY ONLINE COMIC IS NOW LIVE
Winterclaw ( ) posted Mon, 09 February 2009 at 12:12 AM
While it won't produce any lines, try doing a quick render with one white diffuse IBL set at 60% intensity.  That produces a sort of cartoony/painterly effect IMO.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
pakled ( ) posted Mon, 09 February 2009 at 7:23 AM
back in the day there was something people would do witth 'squishing the z axies', unless it's already been covered above.
raven ( ) posted Mon, 09 February 2009 at 11:21 AM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=2885157&ebot_calc_page#message_2885157
You could use the Toon wacro in the material room to achieve a toon effect like I did in this old post.
Also, in Poser 6 and Poser 7 Sixus1 provided toon materials in the material room.
Miss Nancy ( ) posted Wed, 11 February 2009 at 12:10 PM · edited Wed, 11 February 2009 at 12:14 PM
see above for poser toon chader (wacro) with edge-blend lines. the main differences between edge-blend lines and poser toon outlines:
  • toon outline puts a jagged line around the outside of the figure or cloth item, which causes oddities like finger bloat (bad)
  • toon outline can't do interior contour lines
  • toon outline can't do variable line widths in same render
if one just wants a black-n-white image, then skip the toon wacro step. reset all mtls to white with D3D script (or similar), apply edge-blend node to ambient value, render with no lites. I daresay they will have this more formalised and user-friendly in the upcoming P8 beta.
geoff1 ( ) posted Mon, 16 February 2009 at 12:33 PM
http://inkulator.sourceforge.net/
Can I recommend Ink9000 at Sourceforge. Its been a while since an update but does a good job of comic book renders if you take the time to play around. And it is free!
mikachan ( ) posted Sat, 23 May 2009 at 1:14 AM
For daz studio there's a couple of toon shader sets here as well as for poser. For DS threre is a wonderful set at daz3d.com. Just run a search for toon shaders.
