Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 09 8:30 pm)
Hey Jasonh04, did your the files come as a zip or as a Daz installer. If they are in zip from use your zip program to open the zip. If you browse into the folders in the zip (using your zip program as a viewer) you should be able to see the path used to install the mat pose files and textures. My guess is that they will be in the pose folder of the runtime you unzipped them to. If they came as a Daz installer it's not as easy to figure but again look in you pose folder as a start.
Quote - I just recently added some textures for Morphing fnatasy dress...Nothing is showing up. could anyone help.
Go download P3DO from http://www.senosoft.com/ It's Free.
It's also available here in the Free Stuff area.
Aside from all the cool, nifty things that it does (which is A LOT), it will tell you what files something uses. So, you can select a cr2 and it will list all the object, texture and material files it uses. The same can be done for props, materials, entire scenes, etc..
It really is handy for finding where creators have hidden their textures/objects and such. Not everyone creates directories with their name or the name of the object/package for easy reference.
