Sun, Jan 26, 5:49 PM CST
Subject: Strange artefacts in rendering...
gaff ( ) posted Wed, 18 February 2009 at 6:42 AM · edited Sat, 25 January 2025 at 3:55 PM
Hi there!
I get strange black artefacts (as shown on the pic) when I render some of Stonemasons buildings.
Is this a polygon thingie?  I´ve tried with and without "smooth polygon" but no difference...
This happens when using lights with Raytrace shadows.
( I always adjust the shadows by settting shadow blur radius to 1 and shadow min bias
to a lower number (around 0.2).)
Would be happy for some help!
gaff
thefixer ( ) posted Wed, 18 February 2009 at 8:27 AM
That looks like a shadow bias problem to me.
I've seen figures before for it somewhere when I used to use Poser for rendering.
IIRC you may have to set it really high to get rid of it, typically 5 or 6, then again IIRI it could be the other way [lower], but you already have lower setttings, so I'd go higher!
Injustice will be avenged.
Cofiwch Dryweryn.
CaptainJack1 ( ) posted Wed, 18 February 2009 at 8:46 AM
I have had problems with some of Stonemason's stuff (more in animations than in still pictures) because of the intensity of the bump maps. Scaling back the intensity of the bump maps in the material room (or getting rid of them altogether, depending on the look you want) may help.
Anthanasius ( ) posted Wed, 18 February 2009 at 12:09 PM
Can you post a bigger picture ? May be you're settings are correct, it seem youre shadows dont follow youre character, im i right ?
Génération mobiles Le Forum / Le Site
gaff ( ) posted Thu, 19 February 2009 at 8:41 AM
thefixer and **CaptainJack1
**I will try both your suggestions. Thanks!
Anthanasius
No, if you look closely you will see his shadow on the ground.
