You could try BagginsBill's VSS with the PR3-Version of his skin shader.
A ship in port is safe;
but that is not what ships are built for.
-"Amazing
Grace" Hopper
Avatar image of me done by Chidori.
On Face_Off's home page (sorry no URL) he explains how to edit RealSkinShader to work with new figures such as M4 or "old" ones such as Miki 1020. You open the file and look for the comma separated list of material names and add the material names used on your given figure... mine is edited to work with everything from the Poser 4 figures through V4 including Apollo and the EF figures. You can get the material names to add by looking at the figures pull down in Material Room. The script is just a .txt file with a .py extension and you can edit it with note pad or any other text editor that saves .txt without adding formatting junk.... I use EditPad Lite which can open huge .cr2 files instantly and has good search and replace functions. I need to see if I can edit the script to give me slightly cooler under tones.
Quote - Yeah, I think it died. I was hoping someone would post their script.
They wouldn't be able to post the whole script because it's part of a commercial product.
Wouldn't like to speculate on whether a diff would be OK.
Modifying it (provided it's not compiled like the V4 one) for another figure isn't that difficult (list of material zones, and OBJ filename check need attention).
Just remember that you won't be able to use the mask/distribution control images for a figure that has a different UV map than the one the script was intended for.
This is Paul's URL for the Real Skin Shader support page:
http://www.users.on.net/~pkinnane/RealSkinShaderSupport.html
Hugz from Phoenix, USA
Victoria
Quote - This is Paul's URL for the Real Skin Shader support page:
I didn't see any mention of M4 in that thread. Alot of other figures were mentioned.
I feel like a dork these days... so many questions. Is Real Skin Shader just not compatible with M4? It seems to run its course, but doesn't do anything? I haven't had any issues using it with other characters... but is M4 just a no go? R
