Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 22 2:04 am)
You In the daz pose file, under morph injections should see inject viki base, Morphs++, and Aiko4 if you have her. Those will inject everything at once from their perspective groups.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
Quote - Why did V3 poses inject only the dials needed for a dial spin character while V4 characters require all the dials be injected before applying the Character pose? Is there a reason V4 character poses don't include the "readscript" to load the dials?
I haven't used V4 much, so I could be wrong, but it looks to me like this is just bad coding by the people creating the injection poses. I can't think of any reason that the poses could not use readScript to load the the ++ morphs, and only those ++ morphs needed for the specific injection.
Here I get a bit nostalgic. At one time it seems to me that people opened up Poser files, experimented with them, and leaned the way that Poser library files (like pz2) worked, largely because they had to in order to archive anything useful. Today people just use utilities to build the pose files without understanding what they are doing. :(
big hugz for pjz99!
Now all we need is a lil script that will read through a character's INJ file and write the new .pz2 file, or at least the lines to insert.
Who is up to a little scriptease?
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
This is a little script that will inject the 4.2 ++ morphs and the ones for Aiko. If not needed, remove the Aiko line.
version
number 4.01
readScript ":Runtime:libraries:Character:DAZ People:Victoria 4.2.cr2"
readScript ":Runtime:libraries:!DAZ:Victoria 4:Deltas:InjDeltas.V4Morphs++All.pz2"
readScript ":Runtime:libraries:!DAZ's Victoria 4:Morph Injections:INJ Aiko V4.pz2"
Have fun
Ulli
Jules53757... thanks, but you missed the point I think. We only want to inject the morphs that a specific character actually uses.
This would involve reading through the character's INJ file to see which Morphs++ are used, and writing out a script (as in the first part of pjz99's example) to inject only these morphs... or even doing it itself.
Izi
what I should be."
Murakami)
This is something that I tend to think the vendor ought to do, rather than have dozens (or hundreds, or thousands) of people fixing a single person's laziness :)
Yeah, a little app or script that would read a pose and add only the appropriate V4 readScript lines to it would be so cool... make a REMpose even.
Something even cooler would be a script or app that could read a .pz2 for the given morphs and thier values for a character and consoladate them to a single morph per body part at their given settings saved as a PMD file and create a .pz2 to load that as a n injected .pmd doesn't need to occupy existing channels. Means the figures would be so much lighter since after compiling the standard dial setting character pose and creating a PMD injector for the resulting composite morph just one channel per body part would need to be injected. I would pay for that if it could consolodate morphs for different figures.
Something to warn you about with V4 in particular, if you're going to try spawning morph targets and consolidating morph data, you have to be very careful to avoid dials that surreptitiously scale bones, as they will not be included in your morph target and will lead to fruity mesh.
I quite agree that the vendor should do it.
But none of them do (?) and almost certainly never will for current or old characters.
So it would still be good to do this for the characters I already have.
/me sighs heavily and opens the Poser Python manual at page 2.
what I should be."
Murakami)
^^ That is not legally distributable, unless it's an entirely original morph - if any of the DAZ (or whomever's) morphs are used, then they cannot be bundled into a "new" morph target. It's legal to pass around "MOR" poses that dial the values up, not legal to distribute the deltas.
I just checked it with one of my characters. If I create a pz2 out of Poser from my char with All morphs injected, the file size is 699 kB, with IPB and the zeroed channels excluded the filesize is only 14 kB each the INJ and the REM file. Without excluding the zeroed (unused) morphs the filesize is about 102 kB. Both files, build with IPB don't need the pre injection of the morphs and only the needed morphs are loaded into the figure.
Just an example:
version
number 4.01
// Generated with DAZ INJection Pose Builder (IPB) v1.5
// This file is intended for use with Victoria 4.2
// --- Delta Includes ---
readScript ":Runtime:libraries:!DAZ:Victoria 4:Deltas:Morphs++:InjDeltas.FBMVoluptuous.pz2"
readScript ":Runtime:libraries:!DAZ:Victoria 4:Deltas:Morphs++:InjDeltas.PBMInhale.pz2"
readScript ":Runtime:libraries:!DAZ:Victoria 4:Deltas:Morphs++:InjDeltas.PBMBreastsSize.pz2"
readScript ":Runtime:libraries:!DAZ:Victoria 4:Deltas:Morphs++:InjDeltas.PBMBreastsLarge.pz2"
readScript ":Runtime:libraries:!DAZ:Victoria 4:Deltas:Morphs++:InjDeltas.PBMBreastsImplant.pz2"
readScript ":Runtime:libraries:!DAZ:Victoria 4:Deltas:Morphs++:InjDeltas.PBMBreastsNatural.pz2"
readScript ":Runtime:libraries:!DAZ:Victoria 4:Deltas:Morphs++:InjDeltas.PBMBreastsDroop.pz2"
actor BODY
channels
valueParm FBMVoluptuous
keys
k 0 0.168
valueParm PBMInhale
keys
k 0 0.292
valueParm PBMBreastsSize
keys
k 0 0.816
valueParm PBMBreastsLarge
keys
k 0 0.072
valueParm PBMBreastsImplant
keys
k 0 0.292
valueParm PBMBreastsNatural
keys
k 0 0.228
actor lShin
channels
targetGeom JCMKneeBendL
keys
k 0 0.020
Ulli
Quote - I quite agree that the vendor should do it.
Syltermermaid apparently does - you don't need to inject Morphs++ for her characters (well, some of the older ones). I think I may have seen one or two other vendors, as well, but not often.
In truth, though... I almost never use a character with the developer's morphs straight up, anyway. I always feel compelled to morph something in order to make it my own a little bit.
______________
Quote - Something even cooler would be a script or app that could read a .pz2 for the given morphs and thier values for a character and consoladate them to a single morph per body part at their given settings
svdl created such a script (though it produces a pz2 not a pmd). It is called "SpawnCharacterP6 update", and available from svdl's free stuff.
The SpawnCharacter script doesn't analyze .pz2 files. Instead, it analyzes the currently loaded character and consolidates all morphs into a single INJ/REM pose.
I'll have to update the script to handle the magnet system that V4 uses. When I have time....
when you buy a character for poser that says Please be sure to INJect the Morphs++ into Victoria 4 before using the Body MOR file. do you have to inject them all one at a time or is there a way to inject them all at once , there seems to be quite a few to being doing them one at a time
