Wed, Jan 8, 4:53 PM CST
Renderosity Forums / MarketPlace Customers
Welcome to the MarketPlace Customers Forum
Forum Moderators: tim, msansing, ebasham
MarketPlace Customers F.A.Q (Last Updated: 2025 Jan 06 8:41 am)
Contact and Support Information:
To reach our Marketplace staff, please open a support ticket at
support.renderosity.com
Our goal is to respond to support tickets within 24 hours, 7 days a week.
Subject: Fantasy Forest missing it's objs, no response from vendor.
unrulywitch ( ) posted Sun, 22 February 2009 at 2:14 PM · edited Sun, 22 December 2024 at 2:54 PM
I bought the the Fantasy Forest package and expansions from ETDA, (Extreme Themes Digital Art) back in December of 2008. When trying to use the product in DAZ Studio,(specifically the background props), , it asks for the obj files from the Runtime/Geometries/props folder which do not exist. I have re-downloaded and checked the files it is asking for, they are not there. They appear to be planes or box primitives? I have tried the contact for the vendor and have gotten no response. I really would like to use this product and am not looking for a refund. Is this vendor still around? If not can someone instruct me on how to build the props myself and what size, etc. I need to make them? I have Hexagon, or I could try the primitives in DAZ. I would so appreciate any help I could get.
Thank you in advance,
Michelle Beck
PrestonW ( ) posted Sun, 22 February 2009 at 2:23 PM
Hi Michelle,
This product  is for Poser 4, ProPack or Poser 5. It is not for DAZ Studio so this could be the main reason you cannot get it to work.
unrulywitch ( ) posted Sun, 22 February 2009 at 2:42 PM
Thank you Preston for your prompt reply. The file structure is the same for both programs and most products that will load in Poser, will also work in DAZ. The material handling is usually where issues arise between the two, but that is not the case here. The problem is there are basic files needed to load the product that are just not there. I just tried again and found that if I try to load a scene file, I get the terrain prop and the tree props fine, but the background, fog, and the ground files are asking for their obj's, which appear to be simple planes and the ground is asking for a box file. I think the vendor simply forgot to include these simple primitives and so I did manage to create a plane and load the fog and its transparency files using my surface tab, (material editor in DAZ). I also just loaded a background from the texture folder using "edit/background". The ground file shows up in the scene tab, but not in the viewer, and also is not in my surface tab. So at least for the ground prop, I will need to build a box primitive to utilize it. It would be helpful if the vendor could supply the missing files, or if someone could recommend correct sizes and how to build/save them for usage in DAZ for me.
Thank you again,
Michelle Beck
PrestonW ( ) posted Sun, 22 February 2009 at 5:37 PM
I guess i misunderstood Michelle. I will send a message to try and contact the vendor about this.
AnnieD ( ) posted Sun, 22 February 2009 at 6:49 PM
Michelle...
I have this problem once in a while...the path is usually wrong and i do a search for the obj file and then point Daz to it.
“For those who believe, no proof is necessary. For those who don't believe, no proof is possible.”
[Stuart Chase]
unrulywitch ( ) posted Mon, 23 February 2009 at 1:20 AM
Thank you Preston I will keep an eye out for a reply. Thank you too Annie, but the problem is not the path. If I open the runtime on my desktop, the files are not there in any folder, but I do appreciate your time to respond.
Michelle
AnnieD ( ) posted Mon, 23 February 2009 at 1:28 AM
You are welcome...good luck with getting it all fixed.  👍
[Stuart Chase]
BrokenAngel9 ( ) posted Tue, 24 February 2009 at 1:40 AM
 These objs in the props folder the product asks for are object primitives that come with Poser, so unless you have Poser installed on your machine you won't have them.
nruddock ( ) posted Tue, 24 February 2009 at 2:50 PM
Quote -  These objs in the props folder the product asks for are object primitives that come with Poser, so unless you have Poser installed on your machine you won't have them.
Son long as these primitives are only used for something along the lines of parenting several props to for movement purposes, then you can easily make replacements by creating D|S primitives and exporting to appropriately named OBJ files.
