Tue, Dec 24, 6:16 AM CST
Subject: any idea what this is?
lightning2911 ( ) posted Tue, 24 February 2009 at 8:51 AM · edited Mon, 23 December 2024 at 2:30 AM
i created some road objects, added 4 grass planes and did a testrender ... all looks fine.
road 1
then i lower the camera and suddenly the grass goes crazy ... what is this circular shape of the grass planes. the planes are not grouped. it does not happen to the other road objects ... i have no idea what this is. oh ... the more the camera is lowered the smaller the circle radius is.
road 2
wabe ( ) posted Tue, 24 February 2009 at 9:07 AM
What material (grass) is that? And what is the mapping method for this material? Maybe a change in that mapping method changes this behavior.
lightning2911 ( ) posted Tue, 24 February 2009 at 9:20 AM
the grass material is grass-generator from the stones and groundcover package ... the mapping is world standard ... and i found that i also cannot add eco-system and populate.
so i saved the road stuff as an object, created a new scene, added 4 grass planes ... and now it works?!?
i guess somehow the file went bad ... it's been a long day at the office :-)
dburdick ( ) posted Tue, 24 February 2009 at 9:29 AM · edited Tue, 24 February 2009 at 9:30 AM
Hmm, That's very odd.  Looks like some sort of camera distortion occured.  One question.  Why are you creating 4 grass plane objects instead of a single grass plane object?  Is it just to allow for different eco's on each of the planes?  Nice looking grass by the way.
lightning2911 ( ) posted Tue, 24 February 2009 at 11:16 AM
i created 4 planes because the road level is lower but come to think of it i could create one plane and add a transparency or alpha mask i guess ...
and yes, the grass is very nice! thank the creator of stones-and-groundcover :-)
ShawnDriscoll ( ) posted Tue, 24 February 2009 at 11:11 PM
Looks like you're limiting the camera's view range for the grass plane.
lightning2911 ( ) posted Wed, 25 February 2009 at 12:22 AM
but how would i be able to do that? i have not found an option for that to set.
ShawnDriscoll ( ) posted Wed, 25 February 2009 at 12:56 AM · edited Wed, 25 February 2009 at 1:04 AM
I've seen it somewhere.  I'll have to look for it.  Is it Vue 7 Infinite you have?
Did you happen to use a cut-off filter for your lighting?  If the light was conic in shape for instance.  Maybe too late now, but did the grass plane have any cut-off in the OpenGL window before rendering?
lightning2911 ( ) posted Wed, 25 February 2009 at 1:58 AM
its vue7 xStream which is the same as Inf i think.
i just used the default athmosphere scene added the objects and rendered. did not alter anything.
the open-gl worked fine. i actually found where i could set the clipping for open-gl.
i think it must have been some bug or bad state of the system as it worked after restarting.
sometimes i get the feeling that vue has a personality of its own. after a long day without breaks it likes to do stupid stuff more often ... :-)
