Attached Link: Loader
My old Loader script does this job nicely.It was meant as a universal loader for everything, but some of the
functions didn't work after P5, when multiple runtimes were introduced.
The morph loading part still works well.
My python page
My ShareCG freebies
Attached Link: "The Poser Figure" tutorial compliments of Dr Geep Studios
Introducing the Full Body Morph (FBM).
View 'em in good health.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Sorry, but that makes no sense, as I'd still have to load all the morphs. I think you have misunderstood what I was asking for, Geep.
I just want to avoid the pain of loading in morph targets, in the first place. Sorry if I was a bit unclear. Thanks for the suggestion and tutorial.
Meanwhile, I still would like a good autoloading method if there is one
http://www.philc.net/PTB_page3.htm#loadMorphs
PhilC's Poser Tool Box can load morphs into a prop from a modified prop. Unfortunately it's not free.
I can't load it for a screen shot right now but on the left toward the bottom are the import object as morph option and you can drag over to select a whole folder of .obj files in the file selection on the right... this will load the whole batch on the selected body part. It will not import FBMs though. You would have load up each body part of the prop and then dial up the morphs on the body parts to make the FBMs. You can import FBMs from .obj for each part or a single total mesh using PhilC's Poser Tool Box but that cost money and will do only one morph set at a time. I guess this is very well explained but it is the best I can do right now.
momodot, thanks, I finally got it! For some reason, at first it (the script) wasn't allowing me to select multiple files. I doesn't like ctrl shift selection or dragging, I found out, but it finally let me select each one with a seperate click, and I knew I was home free. Thanks! Thanks yet again to Ockham for the free scripts, saving the day!
in Poser 7, I'm starting with a (custom) obj and have a bunch of (custom) morphs, I'd just rather not load them in one by one. Is there an auto loading method or script ?
