No, as a leaf Carrara only can read one shade domain... I tried to group objects and didnt work. I posted this as a feature in the bug track more then a year ago and they never did nothing about that. What will really work is to use one shade domain and a texture, this way you can have the leaf in one color and the fruit in another.
Other way is to use my tutorial to create fruits that you can find in Daz, but its pretty simple: duplicate your tree and in one you add the leaves and in another you add the fruits...
Follow me at euQfiz Digital
For the correct placement under the branches, I create a Distribution Shader who's color channel uses Natural Function > Snow but I invert it with DCG's Shader Ops so the distribution white is on the bottom of the branch.
Of course the fruits Hot Point needs to be at the "top" of the fruit.
It's like a magician's trick. Once you know how it's done, it's obvious - and less fun! ;-)
Mark
Hi Brian,
Seriously large pears for such a little tree!
Like most things in 3D, there is always a little bit of finesse and seldom is a perfect solution attainable for something complex like this. But there usually is a best or pretty good solution! ;)
I can't provide a bullet-proof fix-all for you but heres the things involved that I play with:
You might try increasing the accuracy of the placement to Best. Also, the tree itself is an elaborate algorithm and not actual geometry. The placement function of the Surface Replicator is math magic too. So, there probably is a margin of error that will be more evident on certain tree set ups than others as fixed geometry is expected to orient to bounding boxes and Render-time geometry.
Increasing tree fidelity, adjusting propagation and other little items can help. Slightly repositioning the hot point of the fruit can help. Also allowing the fruit to rotate randomly on the Z axis can provide better fits. Scaling the fruit differently helps significantly.
It's all therapy man.... :D
However, when loading this new Leaf onto a plant I only get the one shading instead of the two.
Is there a solution?
Brian
bwtr
