Tue, Dec 31, 10:09 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Dec 29 10:47 pm)
Carrara Free Stuff here.
Subject: Sequenced .jpg in Carrara 7 Pro
mhscspo ( ) posted Thu, 12 March 2009 at 10:37 PM · edited Tue, 31 December 2024 at 10:05 PM
I inserted a plane and I then went to the texture room and opened up a sequenced.jpg of some animated water. I then rendered it but there was no motion it looked as if it was just a regular picture. Would someone please tell me how to go about this, the correct way of opening up sequenced files?
MarkBremmer ( ) posted Thu, 12 March 2009 at 10:44 PM
 Carrara does not process sequenced files as animations for textures - they have to be in an actual .mov or .avi format.
bwtr ( ) posted Thu, 12 March 2009 at 10:54 PM · edited Thu, 12 March 2009 at 10:55 PM
Just a thought?--I may be wrong!
Brian
And I was!
bwtr
mhscspo ( ) posted Thu, 12 March 2009 at 11:22 PM
I thought that it could be used this way since it is one of the options in the drop down box, it even asked to makes sure of the correct frame rate .
MarkBremmer ( ) posted Fri, 13 March 2009 at 7:41 AM · edited Fri, 13 March 2009 at 7:43 AM
 Well, you are right and I am wrong. That little feature crept up on me since I don't use a lot of animated textures.
Here's how to make it work:
  1. Import the the sequence at the point in your timeline you want the animation to start - this sets a key frame.
  2. move the timeline indicator in your time line where the animated texture should stop
  3. Advance the little movie timeline control in the texture window to the end of the move - this will set a new key frame and engage the texture as a movie.
Thanks for bringing this to my attention!
Mark
mhscspo ( ) posted Fri, 13 March 2009 at 4:15 PM
Thank you sir that was it and now I have the hang of it!!!
