You would need to post your current lights and render setup.
But I'd start with disconecting the texture of your background prop from the diffuse channel and plug it on alternate diffuse, set diffuse value = 0 and specular = 0.
Take a look at this thread
www.renderosity.com/mod/forumpro/showthread.php
Is the specular color for the plane object set to black? If not, the washed out look is probably a highlight.
Why don't you just render the character in an empty scene and combine the output with your image, don't worry about putting it on a plane in the scene at all.
Sometimes, importing it as a background image will throw the proportions of the pic out of whack at render time. It'll preveiw correctly and render wrong. So manually plugging it in is a better idea.
There's not really a "once size fits all" setting for Poser :) It all depends on what you're rendering and the mood ect you're aiming for :)
The image at the back of Simon is a scaled up plane with a picture attached to it in the material room. Pls can someone tell me how to use the firefly render or put some firefly settings that will work well with scenes.
The settings I used to produce the image for both the Preview renderer and the firefly renderer are the same but the image on the plane seems much clearer in the Preview renderer than the firefly and this is the story of all my works.
THANK YOU
