Tue, Nov 26, 9:12 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:57 am)
Subject: Repeating Model Data
CaptainJack1 ( ) posted Sat, 14 March 2009 at 9:21 AM · edited Tue, 26 November 2024 at 9:12 AM
Is there a way to make a prop (or possibly it would have to be a figure) that has multiple parts that reference the same OBJ file? For example, I've made a chain with four links. Theoretically, that could be one OBJ file repeated four times, with a different orientation for each in the final product.
It seems like this would be useful for lots of things... chains, rope, decks of cards, that sort of thing. I suppose to be really useful it would have to be possible to use a different material on each repeated element (as in the deck of cards just mentioned). Seems like a waste of space, otherwise.
If anyone knows anything about this and would like to share, I would surely appreciate it. 😄
Morkonan ( ) posted Sat, 14 March 2009 at 9:24 AM
Do a search over at ShareCG in the poser section for "Chain."  There is a freebie chain set there that uses a python script to help pose/construct the chain.  You might get some clues from there.
TrekkieGrrrl ( ) posted Sat, 14 March 2009 at 9:54 AM
 In a way you can, since Poser will load the same OBJ file for several props. So you could make ONE chain link and import that repeatedly, probably with the help of a Python script that offsets the thing. Ockham made one for me for my modular hallway that works the same way by loading segments :)
Poser doesn't do REAL instancing though like some other programs. Too bad, really.  It is something I'd wish they'd implement in Poser 8.
CaptainJack1 ( ) posted Sat, 14 March 2009 at 10:19 AM
Morkonan, I'll take a look for that chain, and see what's up with it. I guess I was thinking along the lines of distributing a prop, and how big the file would be. I was modeling a playing card on a whim the other day, and it occured to me what a mess it would be to have to repeat the mesh 54 times (gotta have Jokers, being one m'self... :biggrin:)
TG, Instancing would be great, but I'd bet credits to navy beans that the internal structure of Poser's source code is such a nightmare that they won't do it without a ground-up re-write. Wanna take bets on whether that'll happen in our lifetimes? 😄
ockham ( ) posted Sat, 14 March 2009 at 10:51 AM
file_426154.txt
You can certainly reference the same OBJ file as many times as you want in a prop.  Unlike a figure, it takes separate OBJ reference paragraphs. The attached file (without the OBJ) shows the pattern.
My python page
My ShareCG freebies
ockham ( ) posted Sat, 14 March 2009 at 10:55 AM
file_426156.txt
Here's the OBJ file if you want to test the whole thing.  (You'll have to adjust the folder reference.)
My python page
My ShareCG freebies
CaptainJack1 ( ) posted Sat, 14 March 2009 at 11:04 AM
Well, ain't that cool... thank you.
I've definitely learned something, and that makes it a good day. 😄
pjz99 ( ) posted Sat, 14 March 2009 at 1:09 PM
I don't see that there's any real advantage, other than giving you a way to avoid learning modeling. ;)
My Freebies
patorak ( ) posted Sat, 14 March 2009 at 6:37 PM
Me too...You don't suppose it could be used for animation?  Like a chain hoisting something?
TrekkieGrrrl ( ) posted Sat, 14 March 2009 at 7:02 PM
Quote - I don't see that there's any real advantage, other than giving you a way to avoid learning modeling. ;)
Well I can see several advantages to this. You could have a chain (or anything, be it a tube or a tunnel or a hallway) of infinite length, it's just a question of running the python script over again. It's not like you don't have to model the beginning at least (though exactly a chain could be made with Poser's Torus prop if needed)
I know I find the version Ockham made for my Modular Hallway VERY usefull. And ... I still had to model one segment of the hallway... but this way it's up to the end user to decide just howlong that hallway should be.
patorak ( ) posted Sat, 14 March 2009 at 7:15 PM
I agree...anything that can reduce time spent modeling is a God send.
pjz99 ( ) posted Sat, 14 March 2009 at 7:39 PM
Well, you're basically trading time spent modeling with time spent scripting ^^
My Freebies
CaptainJack1 ( ) posted Sat, 14 March 2009 at 7:47 PM
My main thought was to make the file on disk a little smaller. For example, those chain links I made in the example picture in the beginning have 144 faces. It just seemed to me that an OBJ fil with a hundred of those links would be unnecessarily huge is all.
When I was playing around doing a playing card, I put in a lot of faces so I could morph the card every which way, and I ended up with a bunch of faces (over 1500). Now, I wouldn't do a whole deck of cards with each one having that many faces, but if I did, it seems like 1,556  faces would store (and possibly load) better than 84,024.
I'm always up for amodeling challenge, but the programmer in me likes efficient storage. :biggrin:
ockham ( ) posted Sat, 14 March 2009 at 8:51 PM
The chain might be better rigged as a figure, but the card deck would be
the perfect candidate for a one-OBJ prop set, with each card parented
directly to the box.   If the card deck were a figure, you'd have to do all
sorts of fiddling to make the cards stay in each player's hand.
As a prop set, each card can be re-parented easily.
My python page
My ShareCG freebies
DarkEdge ( ) posted Sat, 14 March 2009 at 9:07 PM · edited Sat, 14 March 2009 at 9:08 PM
If someone wants to learn a new way of doing something, maybe we should encourage them.
Just a thought. 😉
patorak ( ) posted Sat, 14 March 2009 at 9:12 PM
Just a thought.
Yeah!  Specially since this could lead to instancing for Poser.
pjz99 ( ) posted Sun, 15 March 2009 at 12:35 AM
Quote - Now, I wouldn't do a whole deck of cards with each one having that many faces, but if I did, it seems like 1,556  faces would store (and possibly load) better than 84,024.
The file size of the OBJ would be smaller (although probably not terribly much, if you compress the OBJ to OBZ format) but memory usage after loading would be exactly the same.  I'm not trying to discourage anybody, just pointing out that this is probably more easily accomplished with a modeler for nearly all uses I can think of, that's all.
And by the way if you're really expecting any significant changes to Poser for the foreseeable future (like, forever), I think you're dreaming ;)
My Freebies
patorak ( ) posted Sun, 15 March 2009 at 4:10 PM
*And by the way if you're really expecting any significant changes to Poser for the foreseeable future (like, forever), I think you're dreaming ;)
Stock ain't doin' too bad.  http://finance.yahoo.com/q?s=SMSI
