Tue, Oct 22, 7:33 AM CDT
Vue F.A.Q (Last Updated: 2024 Oct 17 8:34 am)
Subject: Rendering objects with shadows only
papillon68 ( ) posted Mon, 16 March 2009 at 1:02 PM · edited Tue, 22 October 2024 at 7:20 AM
Hi, I have Vue 6 Inifinite and I'd like, but I don't know if it is possible, to export an object and its relative shadow but not the terrain or ground plane where the above shadow is casted onto.
I tried hide the terrain from render, assigning a transparent material but none of these worked.
Any possibility to do that ?
visit my blog:  www.alessandromastronardi.com
My Rendo Store
bruno021 ( ) posted Mon, 16 March 2009 at 6:21 PM
You should render an object mask from the muiltipass options. You will make the complete redner, and at the same time, Vue ill create an object mask (b&w render you can use in a paint program to cut out the object from the rest of the scene), and a material mask, which is a colour render of the obejct, and nothing else but the object.
papillon68 ( ) posted Mon, 16 March 2009 at 6:29 PM
Thanks for your answer, but this solution would not work if you render an animation ...
BTW, if I understood it correctly Vue7 should have the feature to render shadows only, am I correct ?
My Rendo Store
ShawnDriscoll ( ) posted Tue, 17 March 2009 at 2:50 AM
No shadow catching in Vue.  What you are trying to do might be possible with xStream + Lightwave.
bruno021 ( ) posted Tue, 17 March 2009 at 2:54 AM
Vue can also render shadows only, if you use the shadow pass from the multipass options.
ShawnDriscoll ( ) posted Tue, 17 March 2009 at 3:19 AM
Just the shadows?  Or in addition to the regular Vue render?
