Tue, Feb 18, 4:19 PM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 7:53 am)
Subject: Need some help all my renders are "white".
Daidalos ( ) posted Sat, 21 March 2009 at 2:58 PM · edited Tue, 18 February 2025 at 5:48 AM
Hi there everyone. I really need some help with Poser 6. I'm at a loss here. I cannot seem to pinpoint, diagnose and correct a problem I am having.
The problem everything is rendering completely white. When using IBL lights.
Here is a sample image of what I'm talking about, I'll make another post showing my render settings.
If you guys could help me in fixing whatever the problem is I would be most grateful.
"The Blood is the life!"
Daidalos ( ) posted Sat, 21 March 2009 at 3:00 PM
Here are the render settings.
ice-boy ( ) posted Sat, 21 March 2009 at 3:04 PM
you should not use more IBl lights.
tell us what lights you are using
TrekkieGrrrl ( ) posted Sat, 21 March 2009 at 3:08 PM · edited Sat, 21 March 2009 at 3:09 PM
 The render settings doesn't show up?
Could it be that the image is missing on the IBL? So there's no picture to derive the intensity ect from?
Could you please post a screenshot of the material room with the IBL light selected?
Daidalos ( ) posted Sat, 21 March 2009 at 3:18 PM
Daidalos ( ) posted Sat, 21 March 2009 at 3:19 PM
Sure I'll post a screen shot of the material room momentarily. both advanced and basic.
Daidalos ( ) posted Sat, 21 March 2009 at 3:29 PM · edited Sat, 21 March 2009 at 3:31 PM
Matroom advanced
Daidalos ( ) posted Sat, 21 March 2009 at 3:36 PM
The lights I'm using are the City lights 2 from Tabala's free IBL lights here in the Renderosity freestuff.
Anniebel ( ) posted Sat, 21 March 2009 at 4:26 PM
Quote - Matroom advanced
That is a screen shot of the skin, they would need a screen shot of the light in the material room :m_wink:
The best & most beautiful things in the world cannot be seen nor touched... but felt in the heart.
Helen Keller
My Gallery                       My Freebies                        My Store
las_61 ( ) posted Sat, 21 March 2009 at 4:28 PM
In your render settings under options you have shadows only checkmarked. Try unchecking that .
TrekkieGrrrl ( ) posted Sat, 21 March 2009 at 4:30 PM
 laz_61 hit the head on the nail! (or the nail on the head.. as long as you don't hit your nail on your finger...)
You're making a shadowpass here. With ONLY the shadows and nothing else.
Daidalos ( ) posted Sat, 21 March 2009 at 4:46 PM
Oh Ok, thanks I'll try unchecking that. I thought checking that meant it would render the shadows too, not just shadows only.
Thanks a bunch guys.
ice-boy ( ) posted Sat, 21 March 2009 at 4:48 PM
Quote - Oh Ok, thanks I'll try unchecking that. I thought checking that meant it would render the shadows too, not just shadows only.
shadows only.............only  : )
IsaoShi ( ) posted Sat, 21 March 2009 at 5:30 PM
I would also recommend not using 'Texture Filtering'. This generally blurs the fine detail in textures like skin and fabrics.
Victoria_Lee ( ) posted Sat, 21 March 2009 at 6:55 PM
And you can uncheck the "Smooth Polygons".  All it does is increase your render time with the chance of distorting the figure.
Hugz from Phoenix, USA
Victoria
hborre ( ) posted Sat, 21 March 2009 at 9:05 PM
Drop your Raytrace bounces to 2, decrease your Min Shading rate to 0.2 - 0.3.  You can also uncheck the remove backfacing polys; for your image it is not required.  Then show us your result to determine if IBL is still an issue.
WandW ( ) posted Sat, 21 March 2009 at 9:23 PM
What is the intensity of the IBL?  I set mine at 40% or less.
Cheers,
Rod
bagginsbill ( ) posted Sun, 22 March 2009 at 10:39 AM
Quote - What is the intensity of the IBL?  I set mine at 40% or less.
Cheers,
Rod
The answer means nothing unless you're both talking about the same IBL image. A night-time IBL image at 100% will be 10 times darker than a sunny beach IBL at 10%.
bagginsbill ( ) posted Sun, 22 March 2009 at 10:40 AM
Quote - Drop your Raytrace bounces to 2, decrease your Min Shading rate to 0.2 - 0.3.  You can also uncheck the remove backfacing polys; for your image it is not required.  Then show us your result to determine if IBL is still an issue.
IBL is not the issue. It was a shadow only render pass.
Quote - And you can uncheck the "Smooth Polygons".  All it does is increase your render time with the chance of distorting the figure.
That's all it does? Or do you mean to say you find no value in smooth polygons, because you prefer to see the individual polygons in ears and stuff?
Miss Nancy ( ) posted Sun, 22 March 2009 at 11:27 PM
p.s. in case nobody mentioned, the shadows-only render is not a total loss.
it may be composited over the nostril-glow (no shadows) render in APS or PSP.
TrekkieGrrrl ( ) posted Mon, 23 March 2009 at 3:57 AM
Quote - > Quote - And you can uncheck the "Smooth Polygons".  All it does is increase your render time with the chance of distorting the figure.
THANKS! for a moment I thought I was the only one too ADORE  Smooth Polygons.
If something blows up like a balloon it's because of shoddy modeling OR the fact that the content creator has not bothered to turn off smoothing on the parts. NOT Poser's fault as such. It was never meant for architecture.
