I'm assuming you've done the house-keeping chores?
I’ve just recently started to get problems when working with large Bryce files. I’m also on a home network and everything is usually just dandy but recently trying to save new Bryce files on the older computer has come up with the “ generic failure” error.
Mind you, I’m using Bryce through my network which is on my older computer from my newer computer and saving Bryce files using my newer computer placing the files on the older computer disk. I sometimes get a “generic failure” error when trying to save the file but if I save the same file on the newer computer there’s no problem.
Thank God for the speed of light computer juicing!
Alright fellow Brycers, been a long while since I posted in this here forum, and I ran the usual search, and didnt find an answer. So, here goes.....Just installed the ol' Bryce 6.1 on a second drive, my new 1.5 tb workhorse....the old "c" drive is gettin filled up. Left the first version on the computers primary drive, and installed another version on the new external. Seems to be no conflicts, but, I'm running into a glitch on the newer version(which we all know isn't new, thanks to DAZ). When I try to import an .obp file or .mat file in the create or edit menus, I get an unexpected error(permission error). Uninstalled and reinstalled, and get the same thing. Went to properties and checked and unchecked run as administrator, also did the run in compatability mode, set to Win XP...........all to no avail. Any ideas folks???? Thanks
