Wed, Dec 25, 7:05 AM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2024 Dec 23 6:26 am)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: hiden Blender file???
blueblott ( ) posted Wed, 01 April 2009 at 4:34 AM · edited Wed, 25 December 2024 at 6:51 AM
Hello
I am trying to learn how to use  Blender    (  " and so are we I hear you all say lol")  version 2.48a.
Completed one of Tufts tuts Snowman ok felt pleased  with myself   great!
But now every time I open Blender I get one of the Snowman Blend files opens automaticaly!!
So I have to delete all this before I can start.     plus     It will not let me tab into Edit mode .
I have deleted all the tmp files.
Deleted Blender from add/remove .
Done a search and deleted all files for Blender.that remained.
Disc cleanup/ Defrag
Reg Mechanic
Reinstalled Blender 2.48a
Problem still there !
Re downloaded 2.48a  tried again................same story.
So where can I look for this file ? or is there a program that will search and destroy?
Was on a roll till this happened.
Thanks for any help
Regards Bluebott
haloedrain ( ) posted Wed, 01 April 2009 at 11:11 AM
Sounds like you accidently changed the default scene.  From the noob to pro wikibook:
Quote - InformationYou can change the default scene (and return to a personalized one when pressing Ctrl-X). Just modify the scene and arrange dialogs to suit your needs, then click File > Save Default Settings. Your current scene will now be used as the default when you click File > New. This is very handy indeed. To return to factory defaults, you can delete the file which contains those settings: .B.blend in your home directory. Starting from version 2.44, a new Load Factory Settings item is available from the File menu.
blueblott ( ) posted Wed, 01 April 2009 at 8:56 PM
Hi and thanks .
Yes that works fine except  ...how do you delete from home directory ?
I found the *B.blend  *file but how in the name of the devils trousers do I delete it ?
Thanks Bluebott
blueblott ( ) posted Wed, 01 April 2009 at 9:26 PM
Sorry Haloed Rain,
Managed to delete from search  all is now sweet  but please dont go far away ,seems I may need
you again soon !
(Have found lots of helpful stuff on Wikibook.)
Thanks for help
Regards
Blueblott
haloedrain ( ) posted Wed, 01 April 2009 at 9:27 PM
Navigate to it in your operating system and use the delete key?  Probably Blender shouldn't be running at the time.  If you can't get it to work, though, using file>load factory settings and then file>save default settings will replace it instead.
Warlock279 ( ) posted Wed, 01 April 2009 at 10:38 PM
blueblott - I know how you felt, I did that back a few versions. I'd set up images as backdrops, and had an ongoing model i was working with for a week or two, saved those user settings, then for the next couple months, I spent the first couple minutes every time I loaded Blender, deleting the objects, and removing the images from the backdrop. Nice to  have that "default settings" option now. Course, at the time, it never occurred to me to "scrub" the scene, and save the cleaned scene as the default...doh.
Core i7 950@3.02GHz | 12GB Corsair Dominator Ram@1600mHz | 2GB Geforce GTX 660
Lightwave | Blender | Marmoset | GIMP | Krita
blueblott ( ) posted Fri, 03 April 2009 at 12:48 AM
Thanks Haloedrain  & Warlock 279,
I did manage to remove the file by doing a search for B.blend file .
it returned a file that on other searches it did'nt locate so after moving this to a zip file(so it could not be read) I  opened Blender and everything was fine and back to normal.
But this file was not displayed in the home directory.?
When looking for files where does blender store them.
Blender itself is in C:programs.
along with temp files.
prefetch in windows system 32.
Documents.
Those are the only four spots I could find.
But no matter all is well....so onwards and upwards
Thanks for your valued help.
Regards
Blueblott
haloedrain ( ) posted Fri, 03 April 2009 at 10:28 AM
It's in C:Program FilesBlender FoundationBlender.blender for me.
