Thu, Nov 14, 2:05 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 12:36 pm)
Subject: Need Help
IdolStar ( ) posted Fri, 03 April 2009 at 3:36 AM · edited Thu, 14 November 2024 at 1:54 PM
I bet the poser forum is geting sick of me makeing post LOL i know i am XD but i made a INJ file and i just need someone to test it couse i cant my 2nd pc is dead.  The inj works fine for me but only when i have all the morphs loaded up dunno if thats right or not lol am useing INJ magic i do have inj pose builder but cant get it to work LOL :/. I put the file up in my topc so feel free to test it out and maybe let me know what u think thank you.
http://rapidshare.com/files/216859640/Proxy.rar
hborre ( ) posted Fri, 03 April 2009 at 5:45 AM
For which model figure is the INJ created for?  Will be glad to test, but it won't happen until tonight.
lmckenzie ( ) posted Fri, 03 April 2009 at 6:30 AM
It appears to be for Aiko 4 but it's asking for a slew of files in the folder:
RuntimeLibrariesCharacterRox
e.g. injFBMA4AikoBody-abdomen.pz2
Where are those supposed to come from? I have A4 installed but not those files. I'm guessing you need to distribute those as well? Also, those usually seem to go directly under libraries ather than in characters. BUT, I know virtually nothing about inj other than how to double click one :-) Someone should be along shortly to get it sorted out for you.
hborre ( ) posted Fri, 03 April 2009 at 6:46 AM
I took a quick look at it and indeed it is an A4 which I currently do not have installed yet on my system.  IIRC, there is an added morph set for this model so I'll have to install my base and morphs.  The INJ files must be placed in the Pose folder.  For distribution, the runtime convention must be followed for the files to work correctly.  Unless someone beats me to it, I can test this out tonight when I get home.
lesbentley ( ) posted Fri, 03 April 2009 at 8:04 AM
Quote - "The inj works fine for me but only when i have all the morphs loaded up dunno if thats right or not..."
You can include code in the INJ file to call the files containing the deltas (morphs).
In your INJ file you just use a line starting with 'readScript', then insert the path to the delta file starting at ':Runtime', and inside double quotes, and  e.g:
    readScript ":Runtime:libraries:!DAZ:Victoria 4:Deltas:Base:InjDeltas.PHMCheeksFlex.pz2"
I have no idea how, or if, you can do this with INJ magic, or inj pose builder, as I don't have either of these.
Victoria_Lee ( ) posted Fri, 03 April 2009 at 8:21 AM
I don't know about Injection Magic, I haven't used it in years but Injection Pose Builder produces INJ/REM files that are completely editable in a text editor.
Hugz from Phoenix, USA
Victoria
hborre ( ) posted Fri, 03 April 2009 at 10:04 AM
IPB should and does strip out all zero value morphs when building INJ/REM files.  But IIRC this feature can be controlled within the app; you can determine if you want it or not.  I have played with this program and I do have some familiarity with it.  Again, I won't have a chance to play until this evening.
IdolStar ( ) posted Fri, 03 April 2009 at 12:01 PM
Yea sorry i know i didnt put in a lot of info lol so sorry its for V4.2 Aiko 4 & V4.2 ++
i used inj magic to make it cous i cant get inj pose builder to work at all LOL
so i have to try and get inj magic to work
Victoria_Lee ( ) posted Fri, 03 April 2009 at 12:06 PM
Injection Pose Builder relies on library link files and if you don't have one for V4 (4.1 and 4.2) and for Aiko 4 it won't work.  I'm getting ready to post a tutorial on how to create library files for IPB as well as how to use it to make INJ/REM files and I'm going to put my .ill files for V4 and A4 up in my free stuff.
Victoria
IdolStar ( ) posted Fri, 03 April 2009 at 12:11 PM
XD untill then i will wait couse inj magic is really hard to work with lol
thank you for helping
Victoria_Lee ( ) posted Fri, 03 April 2009 at 12:19 PM
I haven't used INJ Magic for years so I wish I could help you with that one.  If you give me about 10 minutes I'll have the .ill files up in my freestuff.
Victoria
IdolStar ( ) posted Fri, 03 April 2009 at 1:16 PM
Take your time i can wait lol
Victoria_Lee ( ) posted Fri, 03 April 2009 at 1:27 PM
I've submitted the .ill files in zip form for inclusion in my free stuff.  They're on my website but it takes about 24 hours for the freestuff to be approved.  If you need them before then, just site mail me and I'll give you the link.
I still have to convert the tut into .pdf format and I'm working on promos for a new product so it will be a day or two before I get that up.
Victoria
IdolStar ( ) posted Fri, 03 April 2009 at 1:45 PM
I will wait the 24hr. I need to get my poser re installed and set up inj pose builder but thank you so much XD
Victoria_Lee ( ) posted Fri, 03 April 2009 at 1:55 PM
No problem.  I'll get an email when it's been approved and then I'll give you a shout out
Victoria
hborre ( ) posted Mon, 06 April 2009 at 10:50 PM
It took me a while to respond, was having issues with my own Injection Magic but everything has been resolved.  I ran a small test creating INJ/REM files for Aiko 4, tested them and then compared the files with what you created.  Firstly, the files referred to in your Rox folder shouldn't be in the INJ/REM files.  In my own Aiko 4 installation, those files were dumped in the runtime.  (IMO, not very organized).  This explains why the script is searching for those files, originally they don't install into the Rox folder.
Secondly, I believe that the 'Non-zero Morphs only' is unchecked.  Your INJ/REM files are populated with Deltas that are not necessary.  I wonder if the A4 definition files were correctly created.
You would not need to have all the morph files installed, but they need to be present in the same runtime folder for Injection Magic to correctly create the definition and INJ/REM files.  Don't rearrange contents of your folder when creating INJ/REM files.  These files draw on the runtime hierarchy they assume exists on all original installations.  Change something and it will not work on a different computer.
Victoria_Lee ( ) posted Mon, 06 April 2009 at 10:54 PM
If you're using V4, V4.1, V4.2 and/or Aiko 4, my IPB library files are in my freestuff, along with a tutorial on how to use Injection Pose Builder.
Victoria
hborre ( ) posted Tue, 07 April 2009 at 5:50 AM
@Victoria_Lee: remember, Idolstar is using Injection Magic to generate INJ/REM files.  I have tested your definitions for IPB and they work excellently.  Thank you very much for your work.
Victoria_Lee ( ) posted Tue, 07 April 2009 at 9:14 AM
Quote - @Victoria_Lee: remember, Idolstar is using Injection Magic to generate INJ/REM files.  I have tested your definitions for IPB and they work excellently.  Thank you very much for your work.
She, also, has IPB and she said it would go to Parse and stop but I think that's because she doesn't have the right library files.
You're all welcome for the files.  Just a little something to give back.
Victoria
hborre ( ) posted Tue, 07 April 2009 at 10:19 AM
Yes, I agree with you.  Something IdolStar is doing is not translating very well.  I am concerned that specific files have been rearranged contrary to the default installation.  If that is the case, distribution of INJ/REM files will not work on other computers.
Victoria_Lee ( ) posted Tue, 07 April 2009 at 10:41 AM
Which is why my files are zipped from the Program Files directory.  In my notes it says to point the zip program to the HDD where Injection Pose Builder lives and everything will extract to the correct folder.  I thought that was the easiest way since a lot of people don't understand about file structure inside of a program.
Victoria
