Sat, Jan 25, 5:56 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 4:22 pm)
Subject: Adding a bodypart to a magnet
sirenia ( ) posted Fri, 03 April 2009 at 11:12 AM · edited Sat, 25 January 2025 at 5:53 PM
Hi,
Can someone tell me how you do this ?
Example: i select the 'right thigh' and assing a magnet to it, but when i scale the magnet, the shin should be scaling with it but it is not assigned at that magnet.
To demonstrate i exaggerated in the attached pic ;-)
So the question is how to add the 'right shin' to the 'right thigh' magnet ?
Using Poser 6 on Mac OS X
Thanks
Wim
Society failed to tolerate me...
... and i have failed to tolerate society
chriscox ( ) posted Fri, 03 April 2009 at 11:20 AM
Online Now!
Go to the magnets Properties on the Parameter Dials window and select "Add Element to Deform"
Chris Cox
sirenia ( ) posted Fri, 03 April 2009 at 11:30 AM
Ah i see, ok now it works. I was busy trying to do it with the magnet 's zone but i had to select the base !!
No wonder i could not find that add element button LOL.
Thank you :-)
lesbentley ( ) posted Sat, 04 April 2009 at 10:32 AM
Quote - Ah i see, ok now it works. I was busy trying to do it with the magnet 's zone but i had to select the base !!
Actually its NOT in the Base, it's in The Mag.
You can also use pose files to add deformTarget(s) to a magnet that is parented to a figure. This can be handy if you do this sort of thing a lot. For example you can have a pose file that sets all the body parts to be deformTarget(s). You would want to include a number of Mags in the pose file, because you don't just want it to work on a magnet named "Mag 1".
To show you the syntax of such a file, below in the text of a pose file that will add the left buttock, thigh, and shin to the influence of mags 1 through 6.
//DT_Leg L.pz2
version
    number 3.00
magnetDeformerProp Mag 1
        deformTarget lButtock
        deformTarget lThigh
        deformTarget lShin
magnetDeformerProp Mag 2
        deformTarget lThigh
        deformTarget lShin
magnetDeformerProp Mag 3
        deformTarget lThigh
        deformTarget lShin
magnetDeformerProp Mag 4
        deformTarget lThigh
        deformTarget lShin
magnetDeformerProp Mag 5
        deformTarget lThigh
        deformTarget lShin
magnetDeformerProp Mag 6
        deformTarget lThigh
        deformTarget lShin
There are also a number to such pose files included with MirrorMags32, available free from sharecg.
pjz99 ( ) posted Sat, 04 April 2009 at 10:48 AM
Incidentally if you have a whole lot of actors to add to a magnet's influence (like 65 for a project I'm working on right now), it is a whole lot easier to do it via saving the magnet as a prop, and then editing the PP2 file.
My Freebies
sirenia ( ) posted Sat, 04 April 2009 at 2:46 PM
Wow indeed that was stupid of me to type 'base' instead of the magnet itself LOL ... but anyway that was what i was doing (meaning using the magnet itself) :-)
Thanks again :-)**
