Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 06 11:30 am)
Quote - Ah i see, ok now it works. I was busy trying to do it with the magnet 's zone but i had to select the base !!
Actually its NOT in the Base, it's in The Mag.
You can also use pose files to add deformTarget(s) to a magnet that is parented to a figure. This can be handy if you do this sort of thing a lot. For example you can have a pose file that sets all the body parts to be deformTarget(s). You would want to include a number of Mags in the pose file, because you don't just want it to work on a magnet named "Mag 1".
To show you the syntax of such a file, below in the text of a pose file that will add the left buttock, thigh, and shin to the influence of mags 1 through 6.
//DT_Leg L.pz2
version
number 3.00
magnetDeformerProp Mag 1
deformTarget lButtock
deformTarget lThigh
deformTarget lShin
magnetDeformerProp Mag 2
deformTarget lThigh
deformTarget lShin
magnetDeformerProp Mag 3
deformTarget lThigh
deformTarget lShin
magnetDeformerProp Mag 4
deformTarget lThigh
deformTarget lShin
magnetDeformerProp Mag 5
deformTarget lThigh
deformTarget lShin
magnetDeformerProp Mag 6
deformTarget lThigh
deformTarget lShin
There are also a number to such pose files included with MirrorMags32, available free from sharecg.
Incidentally if you have a whole lot of actors to add to a magnet's influence (like 65 for a project I'm working on right now), it is a whole lot easier to do it via saving the magnet as a prop, and then editing the PP2 file.
Can someone tell me how you do this ?
Example: i select the 'right thigh' and assing a magnet to it, but when i scale the magnet, the shin should be scaling with it but it is not assigned at that magnet.
To demonstrate i exaggerated in the attached pic ;-)
So the question is how to add the 'right shin' to the 'right thigh' magnet ?
Using Poser 6 on Mac OS X
Thanks
Wim
Society failed to tolerate me...
... and i have failed to tolerate society
