Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 22 10:18 pm)
I'm a beginner too, but first off, I'd say turn on the TRANSPARANCY for eyebrows and eyelashes (and use a transmap if you have one - there is probably one already in your library - just do a search for 'eyelash'. Second, I'd say on the eyebrows, morph those suckers DOWN (unless you're going for the Henry Kissinger look). :-) Otherwise, it looks like you're off to a good start. ... ummm, well maybe a little color on the lips??? have fun... Ron
Poser 9 SR3 and 8 sr3
Processor Type: AMD Phenom II 830 Quad-Core
Hard Drive Size: 1TB
Processor - Clock Speed: 2.8 GHz
Operating System: Windows 7 Home Premium 64-bit
Graphics Type: ATI Radeon HD 4200
System Ram: 8GB
System Ram: 8GB
It looks like your trans map for the eyelashes does not include any mapping for the eyebrow (some do, some don't), so your image brows are disappearing. Play with the trans settings on the brows (leave the lashes at 100%) but lower the brow trans and see if your natural image shows up - be sure to set the color slider to white for the brows if you want to see the ones in your image and not just a brown blob. As far as lip color goes - mix a little violet (pale mauve) with what you have for a start. Keep it toward the blue side of red (slightly toward purple)and not to the yellow side to avoid a "lipstick look" by all means keep the color saturation low. its looking very good.
System Ram: 8GB
System Ram: 8GB
