Vue F.A.Q (Last Updated: 2024 Oct 17 8:34 am)
Quote - What .obj are you trying to import into Vue? If you have it set up for Poser imports you should be able to import it and then use Vue to find the textures for it.
Ok I've done it. I downloaded Daz Studio unregistered and managed to load the .cr2 file with which the model is supposed to eb loaded. I let Daz Studio export the model and copy it's maps. Working like a charm now.
The object I'm trying to import doesn't even complain about missing textures. The object is divided into 3 folders, runtime and other 2. I can't rig it manually, just too many textures.
Would it theoretically work using a model convertor to convert it to .3ds or .obj? I guess the program would have to detect the texture links of the poser or DAZ3d model first.
